Old 10-21-2010, 12:51 PM
lkappes lkappes is offline
Traction Control Issue
When I start out in the morning I have to back up and turn to get out of the driveway. Every time now it turns the traction control on for a few seconds. After I am moving it never does it again. Is this a speed sensor issue or possibly a bad connection?
Old 10-21-2010, 12:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Traction Control Issue
Welcome to AF.
It could be either one. I would start by inspecting the wiring harness connectors for both front hubs. If no corrosion or broken wires are found, then you most likely have a hub bearing going bad.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-21-2010, 09:35 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
I think this is fairly common when you turn the wheel hard for the low trac light to come on for a few seconds. Of all the GP's I've owned in my life, every single one of them has done it more than once.
however, if it is doing every single time...as suggested I would check the plugs make sure they're all tight.
02 Rendezvous - ABS/Traction Control Issue RGrizzzz Rendezvous 2 11-25-2009 04:04 PM
Traction control issue? NOVAZ27 Grand Prix 2 03-18-2009 07:22 AM
Traction Control Issues probejunkie Thunderbird 0 09-05-2006 02:05 PM
traction controll issues ronjon27 Venture 3 10-19-2005 07:11 PM
ABS and traction control issues... joe4speed Eighty Eight 4 02-17-2005 11:52 PM
