Old 10-21-2010, 09:48 AM
oneroundko's Avatar
oneroundko oneroundko is offline
Need to Push on Gas For my 2.4 to Start
Is this a fuel pump? My car is at 122k and I've had it since 85k five years ago. It's been a champ and I've only had to replace the starter, which I did several months ago. I have not changed the fule filter yet, but now I must push on the gas when cranking for it to turn over, and then it idles fine and runs fine. Could this be a fuel pump? Should I get a diagnostic?
Old 10-21-2010, 08:18 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Re: Need to Push on Gas For my 2.4 to Start
Yes...they can also check the Fuel Pump Pressure....
Old 11-08-2010, 11:48 AM
HannabilRox HannabilRox is offline
A TPS sensor fixed that issue with my Cavalier.
Old 11-08-2010, 03:44 PM
oneroundko's Avatar
I'll have to look into that. In about a month and a half it's going to be like 5 degrees outside here in MN, so I know I gotta get the Cav all prepped for the harsh winter.
Old 01-28-2011, 06:35 PM
oneroundko's Avatar
Haha. Finally got it. I was beating around the bush for the last couple months because I was finishing my degree and drinking like crazy but I finally pinpointed the problem. It was a fuel pressure regulator. I was quoted at $98 for the part and $70 for labor, so I figured I'd do it myself.
The part was $50 at both AutoZone and O'Reilly. I would like to say it was an easy install - and it sort of was - but I installed it two times - both with minor leaks - before I finally got it right. It's a small piece and is accesible with relatively little movement of engine parts.
Anyway, thought I'd post to help any others who might have this problem in the future.
Old 01-28-2011, 07:11 PM
Helmuth48's Avatar
It is about time.. Mate...have a cold tinny on me...Good Job...Cheers !!!
Old 01-28-2011, 07:50 PM
oneroundko's Avatar
No kidding mate. Actually, I would have a cold one on you, but I just got out of treatment! Just glad I got my baby back in good order for the time being.
96 grand am see 2.4 stalls from idle after restarting when warm john murman Grand AM 2 11-29-2010 05:55 AM
1993 4.3L astro van will not start.But by pushing gas down a little bit it will start jebaker2621 M Bodies 4 12-10-2009 07:52 PM
need push bumper for my 96 CV femalevic Crown Victoria 1 09-26-2007 06:42 AM
aftermarket parts for 2.4? lilol89crx Cavalier 3 05-23-2004 01:19 PM
venom super cool fuel pump for 2.4 sohc robertg14 Off-Topic 4 08-27-2003 12:22 PM
