1999 Grand Am Securtiy System Problem
I am having a problem with the security system. Every once in awhile when I am starting the car. The engine will stall and the security light comes on and it is blinking. I then have to wait 10 minutes to reset the system and it usually starts. And sometimes the security light will come on while I am driving. I do not have a remote start. Can anyone tell me what the problem is? Is there anyway to bypass or disable the passlock system? Any help would be appreciated.
Re: 1999 Grand Am Securtiy System Problem
Your car have the passlock II system.
The ignition is probably worn out, so it get a wrong signal... There is a few ways to deal with that. Official and insurance legal way: replace it... I've heard it's about 400$ at the dealer... Annoying way: start the car, then disconnect the 3 wires harness that go to the ignition. Those wires are for the passlock. The result: security light will go on, indicating a problem with the passlock system. It will stay disabled until your battery get disconnected. You will drive with security light always on. Better way: find the 3 wires harness, cut the wires (leave enought wire in case you need to reconnect), connect a resistor between black and yellow to the BCM side, as in not those going to the ignition. The resistor can be any value between 470 and 10k ohms. Solder the wires, tape well. Do the 10 minutes reset. Notice that the last 2 is not insurance legal because you bypassed an anti-theif component! You could also do it at the BCM too, which should be under the glove box. Background on the passlock 2 system: inside the ignition, there is some magnet on top of the pin for the keys. On top of it there is a magnet sensor, called hall sensor. Depending on the height of the pins, the sensor get more or less magnetic field, causing it to have more or less resistance. If the key isn't the right one, so will be the magnetic field, so will be the resistance. The result is that the BCM fall into theif deterant mode. It can happend on worn key or ignition wear, or if there is some wiring issues. Usually it's the ignition that wear out... |
if u have a different key see if it happens with that one to u may just have a bad key
http://www.automotiveforums.com/vbul...d.php?t=685013
Read through the whole thread carefully. There are a few links to other websites (I think Bulldog Security is one of them) to get pictures of exactly which wire to cut. You have to make sure the car is RUNNING when you cut the wire! I did this on my wife's car several months ago, and have had no further issues with the car not starting. Good Luck! Last edited by GregGP; 10-25-2010 at 03:03 AM. Reason: left out info |
the wire cutting only is a bad way. When the car battery will die or get disconnected you're in big trouble! the passlock will reenable, and surprise, your car won't start and blinky will go the light! Really, a resistor should be used |
Yeah, I forgot about that part. you can also use a small switch installed in the wire that is cut. How do you use a resistor? What resistance value is it?
between yellow and black, any value between 470 and 10k.
Then do a relearn procedure. so no need to do any matching or whatever |
what do you mean "relearn procedure"
Life Is A Highway ,Enjoy The Ride
put key in ignition, turn to run, wait around 10 mins until the security light stop blinking, turn to off, wait 5 secs, start the car.
That's good to know. I thought the relearn procedure was something that a dealer had to do.
Actualy thephantom1492, the relearn you posted is wrong and so is the 10 minute thing!
And it is not to expensive for the parts at most part stores. And Yes the stealership will rip you off with their high priced parts.
1999 Grand Am SS 3.4 OHV
Actually, the 3 times come out of nowhere it seems. even the mitchell make no mention of that one. As to the first few steps, it's the diagnostic... which they shouln't have put there... And yes, I have experience with that annoyance... my procedure is the one in my car manual, which is the same as in the Mitchell. |
the Mitchell is one of the mechanics "manual" containing tons of informations, procedure, part location, error code definition and more... expensive thing too... Basically cover every car.
