Old 10-20-2010, 01:40 PM
dannyfiveforty dannyfiveforty is offline
HID xenon noise/interference???
I have installed HID mainbeam headlights to my car, they work great; with instant, bright light.
However, if I have my audio system on (either radio or cd) and I pull the stalk towards me to either flash or pemamently swith main beams on the audio volume dips. It will only do it for a split second though then return back to normal volume, but, if I sit flashing the lights it will dip volume for everytime I pull the stalk...
Is this the effect of poor insulated ballasts? Cables acting as an antenna?
I have already tried installing a new harnes directly from the battery as I first thought they were drawing too much current - but it made no difference.
Thanks for you help
Dan
Old 10-21-2010, 10:39 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: HID xenon noise/interference???
Sounds to me like you're running up against a shortage in current needed to ignite the high beams. The current draw needed by the ballasts is too much so the radio suffers a temporary "brownout" until the HIDs are lit.
Question: does this happen only when you are stopped and at idle or also while driving down the road? I ask because the alternator output at idle is usually much lower than at speed.
Depending on your car/truck, you can do one or two things. 1) Install a higher amperage alternator, or 2) install an inline capacitor to help ignite the headlights and reduce the draw from the car's electrical system. Ask the manufacturer of the HID kit about the availability of this for you application. I'm curious as well since I'm considering a kit for a few of my vehicles.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-03-2010, 11:39 PM
macwan's Avatar
macwan macwan is offline
Send a message via MSN to macwan Send a message via Yahoo to macwan Send a message via Skype™ to macwan
I think you need to check the power of your car first,because the hid kit need high current to start,and you when you turn on the radio or CD,it will make the current no enough to be inputed through the ballast to the xenon bulb,so it will make the bulb flicker
Shenzhen LUMIN Technology Co.,Ltd
TEL: 86-755-28191813
Mob: 86-13570809467
Attn: mac wan
Email: [email protected]
MSN: [email protected]
Skype: wan.mac1
Web: www.lu-min.com
Excellent Auto HID Xenon Kit sunjinguo2007 Corolla/Matrix/Voltz 0 04-30-2010 01:26 AM
Get Hid Xenon Lights For Your Maxima autodirectsave Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 07-17-2001 04:55 PM
