Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-18-2010, 10:01 PM
aztec7fan aztec7fan is offline
Exclamation '98 GGC Laredo stalling problem/solution
OK, hopefully this may help someone else by not having to replace too many good parts.
We just bought an 1998 JGC Laredo and it ran fine for the first week, then started stalling. Our mechanic originally thought it was the CPS (Crank Position Sensor) and replaced it, and we thought that solved the problem since it ran better. They made a comment at the time that the prevoius owner had been "chasing this problem for a while since most of the ignition parts had been replaced (computer, CPS, coil, etc)
In a few days though, it started stalling and we took it back to them. Note, no error codes, and the check engine light never came on. After scratching their heads for a while, the finally did a "wiggle test" on the wiring and found that one of the plugs on the computer was loose, and the plug itself needs to be replaced. I can easily make the car stall by just pushing down on the plug a little.
I temporarily have it working much better by using wire ties and securing the plug down to the computer, but at some point I will need to replace it.
Make sure if you replace it, you get one from a Jeep with the same S/N on your computer. Jeep was very bad about making changes to the computers and systems and you could easily get an incompatible one.
Old 10-24-2010, 02:16 PM
dornier34's Avatar
dornier34 dornier34 is offline
Send a message via Yahoo to dornier34
Re: '98 GGC Laredo stalling problem/solution
Try to check temperature sensor, this can cause the stalling , clean the throttle body and make sure is working the TPS GOOD LUCK , pretty sure you having problem with the temperature sensor good luck Byron
Old 10-27-2010, 02:58 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I'll sticky this thread--thanks for the info!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
1992 Jetta stall problem solution novo33 '91 - '96 2 11-28-2012 11:55 AM
Seat covers for a 98 GGC Laredo pkucan Grand Cherokee | Grand Cherokee SRT8 0 01-20-2009 01:23 PM
1997 Jeep Laredo Stalling JMDB Grand Cherokee | Grand Cherokee SRT8 0 03-03-2006 12:57 AM
95 Laredo stalls/shuts off when turning unreal5 Grand Cherokee | Grand Cherokee SRT8 2 09-18-2004 03:20 AM
99 cherokee laredo stalls please help me marshallmathers Grand Cherokee | Grand Cherokee SRT8 0 11-14-2003 09:40 PM
