Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-18-2010, 01:18 PM
bennuss bennuss is offline
05 century hard start
I have a 2005 century with 130k miles. When the car has not been started for a while it has a hard time starting. Once it starts if i shut it off it then restarts even if the engine is stil cold.if I give it some gas even a drop it starts up. Idle is smooth and no problems while I am driving.
Old 10-18-2010, 06:21 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 05 century hard start
This sounds like you may have a leaking injector that is causing the fuel pressure to drop below an acceptable level when the car sits for a while. The next time you let the car sit turn the key on and wait until you hear the fuel pump stop making a noise and then try to start it. If the problem continues you should have the fuel pressure regulator and the injectors checked.
Old 09-23-2012, 10:09 AM
I dont understand what can be bad about a fpr? I dont smell any gas when i remove the vacuum line and it is just a diaphragm. Also the pressure seems to be right. I have not been able to test it when it does it since it is very intermittent and i dont own a fuel pressure tester.
Also is there anyplace I can find a list of steps to test the vacuum hoses? I own a gm service disk but it does not seem to have it.
Easy to start in morning, hard to re-start after runing? Help please browserealty Suburban 2 08-10-2010 06:01 PM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
98 Century Hard Starting when cold qbeanie Century 1 08-13-2007 05:45 AM
2000 Buick Century hard start/stalling ashbypa Century 0 09-27-2004 07:51 PM
