Old 10-18-2010, 10:35 AM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
ECU's, cams, and fault codes, oh my!
Hey everyone, It has been a long time since I've posted on here, haven't had the time. But now I've got a pretty serious problem that I'm having a hard time figuring out. This forum has been immensely helpful in the past even with the most difficult of questions, so here goes...
Land Rover Discovery 2's will typically throw a P0734 4th gear ratio incorrect fault when the MAF goes bad. Do any of you know why? I've got a few suspicions but am fairly certain that they are all wrong.
That leads me to the real problem. I've currently got 2 of these vehicles in the shop, one is an '04 that had a 4.6L V8 stock, the other is an '00 that had a 4.0L V8 stock. Both had fried their engines and were replaced with re-built 4.6L V8's with big aftermarket cams, same cam in each. Both have new MAF's. Both are throwing P0734. The '04 was throwing P0300 codes as well until I installed an older ECU from a 4.0L truck. These are both Bosch controlled engines. This same cam is running perfectly in my own truck and another customer's truck, but both of those are '96 MY's with Lucas engine management, mine a 4.0L, the other a 4.6L. Two other customers have big cams in their Bosch 4.6's, though not quite as big as these two, they're not having any issues.
So do any of you have any idea as to why this would be or how I can remedy it without replacing the cams?
Thanks for any input or speculation!
99 Neon-CEL on and here's the fault code hink12341234 1st Gen 95-99 1 05-04-2006 07:53 AM
How Do I get the fault codes out of my Jetta paulmckim Jetta/Vento/Bora 2 10-20-2005 01:36 PM
two ?'s tach, and fuel system fault codes hakogen S-10 0 05-01-2004 03:16 PM
1991 5.0 fault codes. 3-2 and 4-3 iggycat1 Sierra 0 04-28-2004 02:29 AM
Check Guages light and 2 fault codes! shepherd Caravan | Voyager 0 03-07-2004 12:05 PM
