Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-18-2010, 08:08 AM
timandsam timandsam is offline
Caprice Hard to Start. Please Help!
Hello, i just bought a 1993 Caprice classic last week and am already having problems with it. It seems that when it is cold outside that the car will crank for like 3-5 seconds until it finally starts. Once it starts it runs great and purrs at idle. I just cant figure out what the problem is. I put the key in and turn it to accessory for a couple of seconds first to let the fuel pump run a while first but it seems to have little to no affect in helping the problem. Also i should mention that the car has the 305 TBI engine in it. The car did sit for a few years before i bought it if that makes much of a difference. Now, this morning i went out to start the car and the battery was dead! Any help would be greatly appreciated!
Old 10-18-2010, 08:16 AM
Scrapper Scrapper is offline
AF Premium User
Re: Caprice Hard to Start. Please Help!
turn your key on and off about 3 times then turn it over and see if it starts if it does i'd say fuel pump.
Old 10-18-2010, 10:26 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Try changing the fuel filter and see if that helps..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-18-2010, 10:49 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I agree with blt2lst - replace the fuel filter. It should be located under the car, near the tank.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-18-2010, 11:22 AM
jd-autotech jd-autotech is offline
fuel pressure regulator could also be the problem
Old 10-18-2010, 06:36 PM
AF Premium User
can you hear the gas pump go zip when you first turn key on or just a click when it reaches carb? if you hear a slight click just by turning on key i say pump if gas filter i would think it would miss but i agree on could be regulator if you hear zip on fuel pump.
Old 10-20-2010, 05:21 PM
j cAT j cAT is offline
with the few year old fuel especially , if it was ethanol you get things growing in the fuel. might need tank / fuel system flushed.
Old 10-20-2010, 09:40 PM
AF Premium User
the TBI still has electric fuel pump in tank.
Easy to start in morning, hard to re-start after runing? Help please browserealty Suburban 2 08-10-2010 06:01 PM
1994 Caprice Motor Disaster! Please help! Musician423 Caprice 18 12-04-2006 09:56 PM
91 caprice back end. please help CaPrIcEkInG Caprice 3 06-26-2006 10:14 PM
97 TD hard to start. Please help! beauplays Ram Pickup | Ram SRT10 5 09-24-2005 01:16 AM
