Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-18-2010, 05:15 AM
96DEVILLE 96DEVILLE is offline
Help !!! 97 deville
The other day my serpentine belt came off.when trying to put it back on i found that there is a single pulley between the a/c comp. and air pump that is bolted into the engin block.well the bolt broke off and the pulley is gone,leaving part of the bolt in the block..there is little room between the block and unibody to drill out bolt.... Any ideas on how i can fix this myself....help thank you. 97 deville northstar
Old 10-18-2010, 07:51 AM
maxwedge maxwedge is offline
A990 racer
Re: Help !!! 97 deville
You will need to remove what is in the way and have the proper tools to remove the broken bolt this is not a job for a " dyer' unless you have the skill/backround.
e 30 isc 90 caddy deville chris90deville Deville 0 03-26-2010 01:50 AM
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 09:04 PM
1988 Sedan Deville inside fan problem Matt137 Deville 1 09-25-2009 10:15 PM
!Help! 97 Cadillac Deville Airbags Maybe Leak? !Help! DkMdville Deville 3 08-25-2006 01:40 PM
