Old 05-20-2003, 10:19 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
Toggle Switch
Okay, well I just got a toggle switch and im still confused about how to hook it up. The one that I got has the three prongs, Supply volts, On Accessory, and the Earth Ground. Now the neon lights that I have, have a box on the wire, and i'm guessing that its the fuse box, but i dont know if I should cut before it or after it. Any information (detailed) would be greatly appreciated and is there any special type of wire that i should use to wire it up? Thanks
PeacE
Old 05-20-2003, 11:17 PM
slave slave is offline
BANNED
I dont know how your NEON's are supposed to be wired but mine have 3 leads too, one for the earth which I wired to an earthing point on the chassis, one goes between the switch and the NEON controller, the other from the controller straight to the battery terminal.
JDM IS NOT LHD
My other car's a Porsche, but today I'm in a hurry.
Old 05-21-2003, 02:10 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i think that box your talking about is liek a voltage regulator either putting out more volts, or stepping it down, or amps i should say. put the switch before that black box
Team Lonely Drivers
Old 05-21-2003, 02:07 PM
Stali08's Avatar
ok so cut the wire after the box and then attatch that to the switch?
PeacE
Old 05-21-2003, 03:26 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
the black box is to set the neons, if u have the one i got ne ways
if it has a switch, it should say, on, off, beat 2 music
Old 05-21-2003, 07:39 PM
Stali08's Avatar
ok, the toggle switch that i got has three prongs, and my neon has 2 wires. what wires connect to what prongs? and can i just use plain old black wire for the ground wire?
PeacE
Old 05-21-2003, 07:59 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
I'll tell ya what ya need to do-I got the same toggle switch. The wire with the box on it-cut it after the box, put that to "on accessory" Run a wire for power (connected to battery i guess) and put that to "supply volts", then the earth ground can just go to-well, i think you can figure where that goes, and also connect the other wire comming from ur lights (the negative wire) to the earthground on the switch. And that should do it.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 05-21-2003, 08:54 PM
Stali08's Avatar
Thanks. what kind of wire should I use to run from my battery? And how should I run it?
PeacE
Old 05-21-2003, 09:07 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
run like a 10 guage should be fine, and run it neatly through a grommet in the firewall and under your carpet and shit, you dont wanna ghetto rig it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-21-2003, 09:08 PM
Stali08's Avatar
ha ha...i guess you didnt read my post on my speakers did you?
http://www.automotiveforums.com/vbul...411#post957050
PeacE
Old 05-21-2003, 09:09 PM
crxlvr's Avatar
yea i saw that, hence why i mentioned not to follow the same path.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Stali08's Avatar
yea ill do it clean this time. where do i connect the wire to on the batter tho?
PeacE
Old 05-21-2003, 09:14 PM
crxlvr's Avatar
the red side
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-21-2003, 10:01 PM
quiXilver's Avatar
ain't that a little large just for lights? I mean, how's he gonna hook up that huge wire through the switch? there's no way! he's gonna have to use like 14-16ga
B18A
Old 05-21-2003, 10:16 PM
crxlvr's Avatar
connector were made for a reason, plus if he adds lights later in life, he wont have to change the wire again.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
