Old 10-17-2010, 08:34 PM
97explorersport 97explorersport is offline
Question Gas line....
I am having a terrible time getting the fuel filter out of my 97 Blazer 4 door. I am going to cut the line and replace it with hose. Is there a special grade hose like one for Fuel injection or can I use the same as a regular gas line hose. I know there is alot of pressure so I thought I would ask B4 it was too late Thanks for anticipated replies.
Old 10-18-2010, 06:24 PM
old_master's Avatar
Advisor/Moderator
Re: Gas line....
If the fitting is the steel line end of the filter, (flare nut) use this: http://shop.advanceautoparts.com/web..._1081395677___ to repair it. Do not use rubber line. Normal operating pressure is 60psi to 66psi but the pump is capable of building up to 108psi, rubber is NOT the way to go.
You have to know how it works,
to figure out why it doesn't.
Old 10-23-2010, 09:59 PM
Re: Gas line....
Is there anything easy on this truck????? I'll tell you one thing once one thing goes it becomes a domino effect. Have a feeling that the Spider and Reg are gone. ........ OLD_MASTER thanks for the info on the gas line. worked great but what a PITA to put in.
Old 10-23-2010, 10:03 PM
old_master's Avatar
Advisor/Moderator
Re: Gas line....
Actually these are quite easy to work on... if you know the secrets. What other problems are you having? Why do you suspect a problem with the injection system?
gas line preasure tester w/bleeder??? importeater38 Yukon 1 08-03-2004 08:05 PM
gas lines streetracer1 Grand Prix 1 06-25-2004 01:51 AM
1993 Camry w/possible frozen gas line JoyNampm Camry/Camry Hybrid/Vista 16 02-23-2004 09:47 AM
Gas line anti-Freeze? bm2boats Engineering/ Technical 1 12-05-2003 02:47 PM
MissFiring or Air in gas lines rob17 Engineering/ Technical 7 08-13-2002 09:04 AM
