Go Back   Automotive Forums Car Chat > Toyota > GS300/GS400/GS430/Aristo
Old 10-17-2010, 04:28 PM
Madcat455 Madcat455 is offline
94 Lexus GS 300
Any help here?? I'm totally stumped on this.
Car has spark, is timed correctly, and has fuel pressure... turns over, but won't run.
Ran horrible, blowing black smoke like a diesel, the night before... check engine light was on, and the next day it'll just turn over and not start.
I tried to pull codes off the ECU by jumping the diag. terminal.. but the CE light just flashed every .5 sec without giving a code.
Looking at it, I found a broken MAF wire (so I soldered it back). The #3 injector wire had a length of wire spliced in with crimps.. so I removed that in favor of solder. Then the #4 injector wire had a bare spot, that may have been grounding on the intake.
Question... since I have air, fuel, spark, and it's timed correctly... shouldn't this thing fire over??
Anything I should be looking at?? I thought a bad sensor, but it should start and run till the ECU goes to closed loop. Maybe a bad ECU?
Thanks
Fully loaded Lexus 300 chop Narkata Graphic Manipulation 4 04-11-2004 05:22 AM
Progress pic of Lexus GS 300/430 (Toyota Aristo) AccordTypeR Car Modeling 33 09-30-2002 05:46 PM
Lexus Introduces Two New 2002 IS 300 Models DVSNCYNIKL IS200/IS300/IS350/Altezza 4 10-14-2001 08:57 PM
