Old 10-17-2010, 11:18 AM
lovemyLS lovemyLS is offline
F150 5.4 loss of power when accelerating
Feels like I'm dragging something behind me. Almost like something is tugging me and lets me go most of the time. I'm getting 14mpg & 8mpg when hauling my boat. The previous owner must have had a chip or something mounted on the dash. I'm sure he hauled things as well but feels like I'm getting terrible performance.
Ive changed fuel filter, flushed the fuel system, flushed radiator, but nothing major yet.. Any suggestions???
Thanks in advance
Old 10-17-2010, 01:58 PM
Scrapper Scrapper is offline
AF Premium User
Re: F150 5.4 loss of power when accelerating
have you checked the timing? also pull plugs out and check the gap it should be under hood on gap. another thing you may want to check e-brake see if there working wright. do you no when the last time 0-2 sensors been changed? some more thing's i can think of is checking all vaccumme hoses. and run some seam foam threw your gas and make sure your air presure on your tires what your truck calls for and don't go by what it sais on tires run what it calls for on truck witch should be on drivers side door. and cat converter can be pluging up also.
good luck.....
Old 10-20-2010, 06:41 PM
jyount jyount is offline
Sea foam is ok, I agree alot with exhaust. I disagree 1000000% on the tires though, DO NOT go by the door sticker, that is the cause of the firestone/explorer fiasco a few years back. Ford had less air in them than the tires were supposed to have. The door stickers are for ride comfort, go with the tire print, and keep in mind, MAX load is Also at MAX pressure, somewhere in between the max and the door is ideal.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 11-14-2010, 02:28 AM
downfal1 downfal1 is offline
Red face Re: F150 5.4 loss of power when accelerating
you didnt say anything about the fuel pump, id check that...
Old 11-20-2010, 04:22 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Also check your catalytic converters . My '96 F150 had no power when I bought it ( used ). I replaced the dist. cap , plugs & wires , fuel filter , PCV valve and cleaned the IAC , MAF , and throttle body and nothing helped ! Finally I had the front cat . converter replaced and removed the second California only required cat. removed and replaced with a straight pipe ( they looked new on the outside but the front cat had disintergrated and plugged up the second cat ) and it made a world of difference in the way the truck runs ! Might not be your problem but worth checking ! Good luck !
" Sometimes I grow so tired "
Old 11-22-2010, 07:57 AM
Jerry Irons Jerry Irons is offline
How is your catalytic converter? This can be a symptom of the converter plugging up. Is there a rotten egg/sulfur smell coming out the exhaust?
99 Escort ZX2 loss of power when accelerating Ron21 Escort 9 12-10-2008 10:42 PM
Loss of power when accelerating jekyll Clio/Clio II/Clio III 0 10-09-2005 12:14 PM
2001 F150 5.4 has no power joesponge F Series 0 06-07-2005 02:12 PM
Loss of power when accelerating. scott'srafro M Bodies 6 04-08-2005 12:33 AM
looses power when accelerating 5-speed dfboiler MX-6 4 05-15-2004 09:29 PM
