Old 10-16-2010, 01:57 PM
katz111799 katz111799 is offline
1990 Astro Van Alternator
I have a 1990 chevy astro van 4.3L I am trying to remove the alternator but having major problems. I was able to unbolt all the screws the problem is I don't seem to be able to disconnect the wires from the back of it thus can't get the darn thing out. Is their another way to get to the back of it besides the feel approach? Any suggestions for this lady would be much appreciate.
Ashley
Old 10-16-2010, 02:12 PM
old_master's Avatar
Advisor/Moderator
Re: 1990 Astro Van Alternator
Disconnect the negative cable from the battery before starting the job. The through bolt, (pivot bolt) is probably a 13mm bolt about 6" long located at the 6:00 position. The lock bolt that holds the alternator in place is located at the 10:00 position, also a 13mm bolt. Both are accessible from the front. There are two electrical connectors: one plugs in and the other is attached with a nut.
You have to know how it works,
to figure out why it doesn't.
1990 doge van b150 318 smokes ronfl04 Ram Van 5 11-21-2009 07:24 PM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
1995 Astro Van alternator problem trikerclyde M Bodies 2 10-23-2005 06:18 PM
Dub City Astro Van Bong_the_Monkey Car Modeling 6 06-04-2003 04:58 PM
****ed up astro van driver... angldrkns9 Stress Release 19 03-29-2001 04:34 PM
