Old 10-14-2010, 03:24 PM
ddoug1 ddoug1 is offline
Temp gauge acting funny and van surging
hi
we live/drive on dirt roads. lots of shaking. '00 astro van started slightly hesitating and the temp gauge would drop. temp gauge would come back to normal and van would run as it should. on pavement it runs ok until a rough spot.
now the temp gauge shows no temp. van seems to run fine.
noticed some sort of sensor on the driver's side of the upper coolant hose and thermostat housing. ideas what the senor might be?
is the temp sensor on driver's side of engine block?
thanks
dick
Old 10-14-2010, 07:42 PM
old_master's Avatar
Advisor/Moderator
Re: Temp gauge acting funny and van surging
Your 2000 4.3L has 2 temp sensors. The one for the ECM is located next to the thermostat housing. The sensor for the temp gauge in the dash is located in the driver side cylinder head between cyls 3 & 5. Two totally separate circuits, not related to each other in any way.
Might want to check the connections behind the underhood fuse panel, common for them to corrode and loosen up. There's a wad of red wires back there, check them all very close.
You have to know how it works,
to figure out why it doesn't.
Temp Gauge Acting Weird madmatt2024 Windstar 10 12-05-2007 11:09 PM
Fuel gauge acting funny red96z3 Z3 9 03-29-2006 06:42 AM
Temp gauge acting NUTS pete44 Cherokee 1 08-21-2005 12:32 PM
temp gauge acts funny ... Hormonx Mustang Problem Diagnosis 2 05-31-2005 10:05 AM
Temp Gauge acting funny - Possible Thermostat Problem? atoyota4x4 Intrigue 3 01-03-2005 09:42 AM
Tags
gauge , hesitates , sensor , temp
