Old 05-20-2003, 08:37 PM
Michael Schumacher's Avatar
Michael Schumacher Michael Schumacher is offline
Send a message via AIM to Michael Schumacher
Best Method For Removing Glued Parts?
Im in the process of dismantling my CLK GTR and Im wondering whats the best method for removing parts that are glued with Testors Cement?
Thanks for any help.
Old 05-20-2003, 08:41 PM
stubacca's Avatar
stubacca stubacca is offline
Send a message via ICQ to stubacca
I've had some good results with the freezer myself - just put the model in a plastic bag in the freezer, and the parts will gradually fall off. Took about 2 days last time I tried it. :coolguy:
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved piece, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW... WHAT A RIDE!
Old 05-20-2003, 08:43 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Brake fluid works too. You have to leave the car in brake fluid for a while, the paint will come off and some pieces that are glued together will come off too. If a specififc parts does'nt come apart, don't force it, you'll probably break it. Good luck.
Old 05-20-2003, 09:23 PM
Yeah I had the parts in CSC for 48 hours (when I was stripping the paint) and they didnt really come apart. Is brake fluid better for stripping paint? I think I'll try the freezer tonight and if that doesnt work I'll go buy brake fluid in two days if its better then CSC.
Old 05-20-2003, 10:11 PM
64 Chevy 64 Chevy is offline
The only thing I can suggest is to slide a razor blade in/under the seam of the glued part and try to pry it off. A good percentage of the time this will work well. Forcing a really stuck part may break the part though.
Why can't I think of any thing clever to put down here?
Old 05-20-2003, 10:46 PM
Slipknot's Avatar
Slipknot Slipknot is offline
Send a message via AIM to Slipknot Send a message via MSN to Slipknot Send a message via Yahoo to Slipknot
Same here with the razor!:flash:
Old 05-20-2003, 10:53 PM
Well if the freezer doesnt work after one day I'll try the razor. Thanks for all the help.
Old 05-20-2003, 11:00 PM
Slipknot's Avatar
Nah just try it for like 2 days like stubacca said.
Old 05-20-2003, 11:02 PM
Slipknot's Avatar
then while it is still froze try popin them apart with the razor.
Old 05-20-2003, 11:22 PM
JE123's Avatar
JE123 JE123 is offline
I just got finished taking apart a model that I finished about 5 years ago. I just used the razor blade technique.
-Joshua
Old 05-21-2003, 01:30 AM
Well since I didnt want to wait two days I decided to try the razor method and it worked out pretty good. Heres a pictures of the now dismantled engine.
I'll be sanding and priming tomorrow along with the chassis.
