Old 10-13-2010, 02:37 PM
Smitty's Buick Smitty's Buick is offline
Oil Pressure Sensor
Last night the serpentine belt decided to "end its life", and in the process, took the tensioner pulley and oil pressure sensor along with it. I have it all put back as good as new, but the oil pressure gauge now pegs past 120 PSI when the car starts.
Is there a procedure to "reset" the computer that I need to do? I did disconnect the negative battery cable for a few minutes, but that didn't help. Did good ole Autozone give me the wrong or possibly a faulty sensor? The replacement was about an inch shorter than the broken one.
The car runs fine, just don't like going for very long without the gauge working properly.
Smitty's Buick
96 PA 214K
Old 10-13-2010, 06:45 PM
maxwedge maxwedge is offline
A990 racer
Re: Oil Pressure Sensor
The wires to the sensor may have seperated in the harness look for that first.
Old 10-13-2010, 09:02 PM
Maxwedge -
I visually inspected the wires. They looked good. I'm fairly positive I have the wrong sensor. The one I installed is described as "Oil Pressure Switch with Light". I ordered one tonight from Rockauto that is described as "Oil Pressure Switch with Gauge". They also listed one as "Oil Pressure Switch with Light".
I'm fairly certain I have the reason identified with the Gauge and Light difference. I will know when I install the Rockauto part. I will let everyone know.
Smitty's Buick
Old 10-14-2010, 08:47 AM
Scrapper Scrapper is offline
AF Premium User
if i buy something from autozone i go to autozone.com and get part number then i'm in the wrong if it don't match up because i have to drive 16 mls. to get it or i just take old part in.
Old 10-14-2010, 08:53 AM
Hey, Scrapper. I took the broken piece (minus the threaded body) in with me. We noticed that the new part was shorter than the original. The plug configuration matched so it was their opinion that this was the right part.
Smitty's Buick
Old 10-14-2010, 11:28 AM
A990 racer
Lite sender is of course different than the gage sender.
Old 10-18-2010, 08:38 PM
Yep! Got the correct oil pressure sensor tonday. Installed it and the gauge reads normally now. Prognosis was dead on! Got my money back from Autozone for selling me the wrong part. It's a good day!
Smitty's Buick
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
