Old 10-13-2010, 08:28 AM
weo38 weo38 is offline
Unhappy Oil pressure concern
When should I be concerned my oil pressure is getting too low? At idle I get about 25psi and at 70mph I get 40 psi. I am running 10W-40 Synthetic oil. I am just getting a little concerned I may be into a rebuild/replacement in the near future. Truck has 102,000 miles on original motor.
2009 Z-71 ECSB
2007 Yamaha Grizzly 700 FI
Old 10-13-2010, 09:17 AM
maxwedge maxwedge is offline
A990 racer
Re: Oil pressure concern
What are you comparing this to, what did it used to be, also you may want to hook up a mechanical gage at the oil sending port and verify the dash readings.
Old 10-13-2010, 10:23 AM
I guess i am comparing it to what i was seeing before. I would have like 40-45psi idle cold and 45-55at highway speeds. Not sure why it would drop off that much. I am a little skeptical of the gauge as well.
2009 Z-71 ECSB
Old 10-13-2010, 09:05 PM
j cAT j cAT is offline
your not to use 10-40wt oil. this oil was banned by GM back in the early 1980's.
your engine should be 5-30wt or 10-30wt. synthetic is best.
why not 10 -40 ????????? because it wears out the engine.
I use 5-30wt synthetic well over 100,ooomi I use 1/3qt at my 8,ooomi oil change . 2000 5.3L silverado original owner..
stay away from FRAM OIL FILTERS !!!!
Old 10-14-2010, 10:24 AM
So you are basically saying I am screwed because I used 10w-40? If I change back to 5W-30 my oil pressure will be less right? I went to the 10w-40 because it was said to be used in high mileage vehicles.
2009 Z-71 ECSB
Old 10-14-2010, 11:18 AM
you could be screwed . check the pressure with a mechanical guage .
40-50 psi when warm is what I get. when at very cold start I get 65-70psi.
use wix,purolator Plus,napa gold oil filters and 10-30wt oil. see what you get for pressure. 25psi at idle is fine/// below 20psi is getting low.
25 psi however is not the normal idle oil pressure.
If you used synthetic from the day this vehicle was built , the engine would have very little wear. hi mileage oil formula is for worn, abused engines that used non synthetic oils, poorly constructed oil filters and going too long on replacing the oil.
the engines in these vehicles go about 200,ooomi . when properly maintained..
Old 10-14-2010, 12:35 PM
A990 racer
One time use of 10-40 will not be an issue, the 10-40 back in the day tended to " coke" up because of higher engine and combustion temps. As j cAT said it is not designed for modern engines.
Old 10-14-2010, 03:17 PM
like you said and I agree the mechanical guage test is needed.
looks like his pressures are off hot / cold by the same amount. the sender is very possibly out of cal..
Old 11-01-2010, 03:11 PM
Happy to report that after a check with mechanical gauge and then an oil change back to 5w-30 the oil pressure is reading higher and more in the range before I changed to 10w-40. The mechanical gauge and the gauge in the truck read about the same at idle cold with 10w-40 (40 psi). After changing the oil and filter the gauge now reads 40 at idle and between 50 and 60 at highway speeds(between 60 and 70 mph). I feel better now and hope to keep these readings as the oil gets used.
2009 Z-71 ECSB
Old 11-02-2010, 01:32 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Sounds about right. Remember the second number is the relative viscosity at operating temperature. So, the -40 oil will be more viscous and thus harder for the oil pump to move than the -30 oil. The -30 oil flows better, i.e. less resistance to flow, allowing the oil pump do less work to move the oil.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Where is oil sending unit 98 Explorer 5.0 Hedhunter Explorer | Explorer Sport Trac 2 02-13-2010 02:19 PM
low oil pressure after engine change? but oil pressure was 60 when pulled! bjrjr16 S-10 2 07-20-2009 12:43 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 01:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 08:27 PM
Oil pressure concern Silver Surfer Grand AM 4 11-01-2004 11:46 PM
