towing a 1988 Trooper
Anyone know if it is okay to tow a 1988 Trooper II w/ a tow bar. It is a 4wd, manual transmission. Do not know if has auto or manual hubs (not my car (yet)).
Thanks! |
Re: towing a 1988 Trooper
Put trans and t-case in Neutral and disconnect the rear drive shaft.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
Why disconnect the rear driveshaft? The T case and manual trans both in neutral should do the trick, imo.
It would be a short ride, just to get it from point A to point B for repair (bad rod). Maybe 30 miles, as a guess...
Thx. I might just call AAA and have them tow it.... |
Even with the t-case in N, the DS is still turning parts inside that may not get lubed properly. Some t-cases (Toyota for example) actually connect the front + rear outputs (4WD) before disconnecting from the trans (N). (Shift pattern is 2H-4H-N-4L).
Disconnecting the DS is an added safety measure. I flat tow my 84 rockcrawler with my 2000 Trooper, I've learned a few things.
The 88 trooper transfer case technically does not have a "neutral". A lot of people confuse the crossover between 4H to 4L as "Neutral", it really ain't. (there's a reason Isuzu didn't label the T/C shifter knob with a "N") It's just in between gears. I have 3 of them. If it's a short tow, just put the tranny in neutral and tow it. Don't go over 45-50 and you'll be fine. i towed one of my troopers 75 miles with a tow bar with no issues.
ernie
2000 Nissan Xterra XS 1989 Isuzu Trooper with a mod or 2 1998 Isuzu Trooper 3.5 with a 5-speed with a mod or 2 1985 Chevy K-10 with a mod or 2 |
