Old 10-12-2010, 04:40 PM
eddiej88 eddiej88 is offline
Question EGR Flow PO401
Hello, i have a 1998 Chevy Lumina that has a PO401 error code. Insufficient flow. My mechanic says egr passages are clear and the EGR valve is good.What else could it be?Does mine have the DPFE Sensor? Could that be the problem.The car has the 3.1 Liter V-6 with 137k. Just replaced the lower and upper intake gaskets, plugs,wires, and turn signal switch. This is the last problem im trying to correct. Thank-You!
Old 10-12-2010, 06:52 PM
maxwedge maxwedge is offline
A990 racer
Re: EGR Flow PO401
Was the code there before the work was done?
Old 10-12-2010, 07:19 PM
Re: EGR Flow PO401
It was on before the work
Old 10-13-2010, 08:15 AM
A990 racer
Re: EGR Flow PO401
Ok, a bi directional scanner can activate the egr and determine whether it is working as the engine will stumble badly at idle. There is no sensor ithe pcm looks at map and airflow.
Old 10-17-2010, 03:49 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: EGR Flow PO401
I've seen a few that had a big blob of oily "snot" laying in the EGR passage as a result of of an intake or head leak...it may look clear on the EGR end, but did he chase through it and actually see?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 10-26-2010, 08:49 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
Re: EGR Flow PO401
agree! he may have meant the egr tube is clear, but the tiny passage from the egr to the inside of the upper manifold is still blocked
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
Egr valve po401 ?x? Escort 8 10-01-2007 05:07 PM
EGR code po401 mommaduke F Series 2 01-21-2006 09:25 AM
low egr flow obd II code saul Grand Marquis 13 05-03-2005 08:43 AM
egr flow problem jhope Accord/TSX/Accord Hybrid 1 10-05-2002 04:29 PM
