Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-12-2010, 02:41 PM
jrodtaclet jrodtaclet is offline
Wink 97 Rodeo Blower Not working
Hello, My blower stop working and was not working on any speed from 1-4 it was all dead. I read here how to fix it and now it work like new. I remove the blower and tested with the car battery, the motor worked. So I knew the motor is fine. I tested the blue and white wires and I was getting no current. I check the fuses and there was not current. I did not know that I have to have the car running in order to have current. After removing half of the dash board to test the speed control unit I read here that if the car is off there will be no current. To make a long story short I had to replace the Fan blower resistor. From what I'm reading is either going to be the blower or the resistor that goes out. If the blower is working, do a bridge from the resistor on the middle prong=hot to the one that says H=speed and the blower should work. Then you know your resistor is bad. The resistor is behind the glove box right in front of you. Here in the picture I have removed the old one and placed in the new one.
Old 06-05-2011, 05:15 PM
IceJoe IceJoe is offline
Re: 97 Rodeo Blower Not working
I am having the same problem. Your links aren't valid anymore. Do you still have the pictures you could send me? Thank you.
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
ac not working/blower not working jcr5186 Aztek 1 07-19-2006 09:50 PM
90 Astro Van Blower Fan/Blower not working larch303 M Bodies 1 01-07-2006 08:46 AM
Grr.. 93 oldsmobile achieva heater blower not working caddyman379 General Discussion 0 01-14-2004 07:41 PM
2000 Low Speed Heater / AC blower not working btsander Cavalier 1 12-29-2003 08:32 PM
