Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-10-2010, 10:58 AM
perla perla is offline
vss
does any body ever had problems with the vss in a pontiac montana 2000
does any body knows where is located at and how do you replace it
Old 10-10-2010, 12:37 PM
3100 3100 is offline
Banned
Re: vss
why you think you have vss problem? You can find it on the end of the transmission (passenger side). Very easy to replace (one 10mm bolt holds it in place, so just remove the bolt and pull it out)
Old 10-10-2010, 09:00 PM
Re: vss
Well my mechanic work on my van and replace the camshaft sensor and oil but when I got my van back he told me that the vss sensor was bad.Well after I got your replay I look down there and I found that the sensor is not plug in.I do not want to said anything about it but I do not thrust my mechanic any more!
Old 10-11-2010, 05:33 PM
Banned
Re: vss
you are not far from me if you ever need assistance let me know!
Locating Windstar VSS - Replacing Windstar VSS glennet404 Windstar 1 06-19-2009 10:05 AM
Is the 91 civic si VSS the same as the 90-93 acura VSS? Honda_Racer '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-14-2003 03:56 PM
Tough VSS Question about Compatability section525 Engineering/ Technical 4 10-29-2002 08:30 PM
HELP! VSS removal/installation... Kohhal Engineering/ Technical 7 03-13-2002 04:58 AM
VSS install Questions! need reply ASAP!!!!!!!! 13secondcivic '71-'87 Civic | CRX 0 01-26-2002 09:16 PM
