1998 z71 will start and not start
SO I have a 1998 z71 with 289k all original drivetrain miles and it has been fine until now. Sometimes it will crank up and run fine, other times it will crank and run for a second then die, and sometimes it will not crank at all. It was throwing a po304 cylinder 4 misfire and a po300 multi cylinder misfire code, sometimes it runs rough when you crank it up, but typically when its warmed up it runs super smooth, I replaced the fuel filter and it was really dirty. When it does not crank you can tap on the fuel tank and it will start, so im thinking it is the fuel pump, I just wanted some other opinions before I throw down the dinero
Re: 1998 z71 will start and not start
Yea pump, prob due. Make sure you clean tank good before you open it to keep crap out.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
Do you all suggest getting a rebuild kit or a complete new assembly?
did you check for fuel pressure ? DID IT HOLD THE PRESSURE on engine off for 15 minutes , to with in a few psi ? need 60-65 psi. |
Also make sure the new Delphi pump is specific for your VIN!!
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
How do I find out the correct one where in the vin would it state which pump I needed???? Its a short bed extended cab 350 5.7 vortec
just give your vehicle infomation and you will receive the correct pump. they made some pump assy different depending on the emissions regulations . the vin will give the part supplier the necessary info to ensure you get the correct pump. using the vin is normally used to ensure any componets replaced are correct . |
