Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 10-08-2010, 01:32 PM
johnwon454 johnwon454 is offline
1998 trying to help single mother
Hi, I hope someone will take the time to answer this on behalf a single mother in need. Mechanic said rear end is bad, makes a loud noise. I have not heard it or even seen it. My question, is there any reason why the rear driveshaft could not be simply removed, lock it in 4WD and just drive on the front drive? Thanks for your time.
Old 10-08-2010, 03:04 PM
x3mtm's Avatar
x3mtm x3mtm is offline
Send a message via AIM to x3mtm
Re: 1998 trying to help single mother
the front drive axles should only be used in slippery conditions...like in snow. it is not recommended to be used in dry conditions because it can jam the tranaxle gears and break it....along with the transmission. you might be able to get away with it for a couple of weeks, but it wont last long...
Old 10-08-2010, 03:15 PM
Thanks you so much for the reply.
Old 10-16-2010, 09:02 PM
N8ECH N8ECH is offline
Hi John:
While this measure could be ok for a short term solution, Doing much driving without investigating to see what issues if any the rear end has could be very dangerous.
The early Durangos 98, 99, 00 had their share of issues, and rear end problems was one of them.
We would not want this gal to be running down the road at speed, and have the rear end lock up. The rear ends equipped with the limited slip or Anti Spin as Chrysler called it for the Durango have clips that keep the clutch packs in place.
Eventually, they seem to fracture and allow slop which causes big problems if not caught early on.
The front axle housing on our Durango's is aluminum, and not designed to pull the entire weight of the D by itself.
Hope this helps..................................Don
Flame Red 2004 Hemi Durango SLT 4x4
w 3.55 gears.
Old 10-21-2010, 08:53 AM
Originally Posted by N8ECH View Post
Hi John:
Thank you for further information on the subject. I will advise her againt doing this.
Old 11-02-2010, 08:39 AM
Hi John:
I'm still trying to help, can someone please tell what all model years would work and also be model years that are not prone to this issue.
Old 11-02-2010, 09:52 AM
jpb53 jpb53 is offline
You might try this site.
http://www.car-part.com/advSearch.htm
Old 11-03-2010, 01:56 PM
Thank you for your time. I will check it out.
Old 11-13-2010, 04:13 PM
John:
Most salvage places have access to computer programs and or "Hollander" books which tell them which years will interchange.
My guess is that at least 98, 99, and possibly 2000 will fit. Try to avoid a rear end with the factory Anti Spin as you could eventually end up in the same boat.
Also, there were two different gear ratios from the factory for Durangos. The more common being 3.55 to one. The optional 3.92 to 1 is less popular. The replacement rear end has to have the same ratio as the front, or the first time 4 wheel drive is engaged the transfer case will most likely explode.
Don
w 3.55 gears.
Old 11-15-2010, 12:24 PM
John:
Don
Thanks for your reply. Right now this lady is back working and trying to save up some money. The vehicle will need tags, insurance, inspection, etc., etc. As of now, she is using her mom's car and has to drop her off at her job first.........
Single Mother Needs Help Badly With Coolant Problem 1_mad_daddy Alero 15 11-30-2007 07:05 AM
1990 2dr chevy lumina so mang problems help single mother please inkedangel2002 Lumina 10 09-11-2006 08:25 PM
Help With Mother In Laws Car oldsgal442 Cavalier 1 05-18-2006 08:09 PM
I support single mothers clawhammer Non Specific 14 04-21-2006 09:43 AM
Single Mother needs advice Tovio Grand Prix 5 09-03-2005 01:11 AM
