Old 10-07-2010, 06:50 PM
9901gp 9901gp is offline
starting problem
I have a 99GTP with 47k miles. it has a 3.4 pulley, headers and basic supporting mods. Lately eithor it wont start unless I give it throttle while turning the key, or it will kinda sputter and start up. Also, the lighting in the car will get real dim along with the sputtering until its completely running. It runs/drives great otherwise. I changed the fuel pressure regulator, still the same things happen, I was thinking maby the injectors? Any ideas on whats going on? thanks
Old 10-07-2010, 07:24 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: starting problem
Clean the IAC motor and its bore with some carb cleaner.
Then check fuel pressure and make sure its with-in spec. (45psi comes to mind)
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
v70 awd starting problem hot and cold jonnylove V70 0 05-13-2010 04:04 AM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
