Old 10-07-2010, 05:13 PM
MAD King MAD King is offline
O-Rings for Fuel Injection
May someone can tell me how many o-rings I need for the injection what goes into the rail and manifold and if they are all the same size.
Thank you
Old 10-07-2010, 09:24 PM
Blue Bowtie's Avatar
Registered Offender
Re: O-Rings for Fuel Injection
Yes. Someone can tell you.
What year? What engine?
Old 10-08-2010, 07:22 AM
ups. I forgot. 1998 and 3.1
Old 10-08-2010, 07:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As said you need to give year make and engine.
Why are you wanting to know?
Injector problem or other problem?
Fuel rail type Fuel injectors take two O rings per injector.
MT
Old 10-08-2010, 07:30 AM
One injector o-ring is broken and its giving a vaccum leak. I have to replace it, but before I take it apart I need to know about the o-rings.
Old 10-08-2010, 07:53 AM
MT-2500's Avatar
AF - Advisor
2 per injector.
I would replace all O injector rings on that side when you have fuel rail off and consider other side to.
Good Luck
MT
Old 10-08-2010, 08:01 AM
2 per injector.
Good Luck
Thank you, but are they all the same size and how many do I need?
12 for the injector what goes in the manifold and for the rail 2 ?
Makes 14?
Old 10-08-2010, 08:42 AM
MT-2500's Avatar
AF - Advisor
Each injector has two O rings.
One one each end.
One where it goes into intake and one where it goes into fuel rail.
All sme sise.
If you have 6 injectors get 12 O ring's
I always get two extra for a job.
In case One takes off or gets lost or damaged.
A little lube on the o ring and in hole where the go helps install them.
MT
Old 10-08-2010, 08:44 AM
One one each end.
All sme sise.
Great. Thank you.
Old 10-08-2010, 08:48 AM
MT-2500's Avatar
AF - Advisor
You are welcome and let us know how it goes.
MT
Old 10-08-2010, 08:58 AM
I will.
Old 10-09-2010, 05:43 PM
ptcfast2 ptcfast2 is offline
Originally Posted by MAD King View Post
I will.
How many miles are on the injectors? You might want to get them rebuilt/cleaned while you have them out. Made a world of difference on my 3.1.
Old 10-09-2010, 06:30 PM
170.000 miles and the injectors look like new. We changed the o-rings and it drives very nice again.
Old 10-26-2010, 08:47 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
hope you put the brown ones on the inside, black ones on the fuel rails!
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
Classic mustang to 5.0 fuel injection novi Performance 7 09-05-2009 03:05 AM
97 Cav, 2.2L, Fuel Injection O-ring bighead Cavalier 7 11-05-2004 03:09 AM
K&N Fuel Injection Performance Kit for 5.7L V8 chevyman_22 C/K 0 01-12-2004 04:38 PM
