Old 10-07-2010, 04:06 PM
onewayblues onewayblues is offline
What do you all think ?
I found out the self leveling module for the rear air ride shock assy is going bad, when the car is loaded down the system just dont jack the rear end enough.
So after pricing all of the parts needed
I think it would be just as good to do away with that setup and just install some simple air shocks.
OBTW it is a 92 Park Ave.
What say you?
Old 10-08-2010, 10:28 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: What do you all think ?
Are you sure the strut air bladders are not leaking? You can install a Monroe remote air fill kit (Part #AK29) for less than 10-bucks.
Old 10-11-2010, 12:44 PM
kaspr kaspr is offline
If I understand you correctly that your air compressor in the engine compartment DOES come on, but just doesn't stay on long enough to lift the back end sufficiently, then it's probably the air bladders on the rear shocks, so buy the remote kit as HotZ recommended.
Alternatively, it could be the ride height level sensor on the rear right control arm. Unhook the connector from the arm of the sensor to the control arm, and move the arm of the sensor up. If the car doesn't jack up any higher when the compressor comes on, then you know it's not the sensor that is giving you trouble.
To make sure that air is getting to the bladders, you can unhook the air line from the rear shock and then get the compressor to activate and feel for decent air pressure coming out of the air line. To get to the air line you just have to remove the wheel, then you can access it.
Most likely the problem is the air bladders, though.
Just curious what you all think about.......... Enzoenvy1 Car Modeling 27 08-14-2007 10:00 AM
94 prelude S-what you all think? suprachica779 Prelude 11 11-19-2004 11:28 PM
What you all think! boarder50 Mustang Talk 10 05-03-2004 07:54 AM
What You All Think Of This Headlight? amdsoldier Off-Topic 6 12-09-2003 10:42 PM
What you all think of the Volkswagen W12? Scott 02 General Discussion 36 08-06-2003 04:11 AM
