Old 10-06-2010, 05:37 PM
timbrigham timbrigham is offline
F250 Fluid leak
1996 F250 is leaking clear / slightly yellow fluid from panel directly behind the oil pan on the transmission (?). It looks like the gasket is shot (small pieces missing near leak source) and possibly that the panel was stuck when hitting something on the road.
Any issues I should look for beyond replacing the panel and gasket? Also is there anything more to it than the two visible bolts?
Thanks gents
Old 10-06-2010, 07:55 PM
Re: F250 Fluid leak
Forgot to mention - it's a 7.3 diesel with a manual transmission.
Old 10-13-2010, 09:45 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: F250 Fluid leak
Clutch slave cylinder, no fix, needs replacement.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 02-07-2011, 02:03 PM
Re: F250 Fluid leak
In the end it turned out to be the fuel bowl.
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
F250 injector leaking Mud Nut F Series 1 12-30-2007 09:45 AM
87 f250 vacuum leak at manifold 351w 4v sjcrft F Series 5 12-21-2005 09:52 PM
1978 F250 coolant leak 95.5 Rodeo F Series 4 02-20-2004 07:19 PM
