Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-05-2010, 10:04 PM
jpdoyle jpdoyle is offline
Ok experts try this out for a challenge
I'm driving down the interstate in my 97 Contour and everything is just fine. As I exit I65 onto 265 I'm going around a pretty sharp curve for about 15 seconds at 55 mph. About half way through the curve the engine misses and blows a huge puff of white smoke out the tailpipe. It does this a couple times and then stops once I get straightened back out and not whipping it around the curve. After that no smoke at all and the engine runs great again. This happens twice a day everyday at the same spot. Other than that it seems fine.
What in the world could be causing it?
This isn't a trick question; it happens every day.
Thanks!!
Old 10-06-2010, 05:18 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Ok experts try this out for a challenge
I'm no expert, but I have an idea about what happened. You must have pulled so many G's on that corner that the oil in the pan got up into the cylinders. This is what I think happened.
Normally white smoke is water that has been vaporized, but I've heard from other posters that a shot oil going through the combustion chamber will materialize itself as such, also. I hope you got your timng belt fixed up all right . Murphy's law.....
Old 10-06-2010, 08:34 PM
Crazy car actually died on me tonight. Same place, same scenario. Once I straightened back out I was able to shift to neutral and start it back up. Drove fine after that. It's just weird.
Thanks for the reply
Please check this out for me thanks chamkila911 Yukon 0 03-28-2008 07:58 PM
I should try this out sometime L-Spec Videos 3 01-25-2007 12:49 AM
Try this game for size. fredjacksonsan COMPLETELY off-topic 12 07-28-2005 12:15 PM
Try This Out!!! Modify Your Stock Intake To A Cold Air Intake W/o The Pipe! cliffud Engine 7 02-27-2002 09:48 PM
