Old 05-20-2003, 01:10 PM
dishman dishman is offline
Unhappy A/c Fan
THE A/C IS BLOWING COLD BUT IT WILL ONLY BLOW OUT THE FEET VENTS. I BOUGHT A NEW A/C HEATER SWITCH DID NOT FIX ALSO CHECKED RELAYS. (1995 Z-71 V8):
Old 05-20-2003, 09:23 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I believe that you have a vaccum operated system. If you lose vaccum to the door actuators on the air conditioning box the doors are spring loaded and it will go into a default mode usually it is the defrost vents and the floor vents. When you replaced the switch was there vaccum lines attached to it? Chack make sure you don't have a vaccum line off somewhere.
Old 05-21-2003, 05:26 PM
vaccums
there were no vaccum lines connected.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
06 Expl Heater Fan stuck full blast/can't stop! Kirkwwhite Explorer | Explorer Sport Trac 3 04-02-2009 09:17 PM
Envoy Fan WesPomp Envoy 3 03-31-2009 03:28 PM
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
