Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-04-2010, 10:11 AM
POSCarDriver POSCarDriver is offline
Engine Running Cold and Knocking
A couple of days ago my car started making a consistent knocking sound on the highway. It only occurs when I push on the accelerator and when the RPM's go above 3k; usually on hills or the highway. I can feel the knocking on my foot when I have it on the accelerator, so I would assume it is coming from that general area. It hasn't gone away and may have even gotten worse. On top of that I have now noticed that the temperature gauge inside the car is showing the engine is running cold. What would cause this to happen? Any help is appreciated. Thanks.
Old 10-04-2010, 11:56 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Engine Running Cold and Knocking
Welcome to AF!
Usually when running cold, the thermostat is not opening. I would check that out first and replace. Even if it still looks ok, I'd replace it. It's cheap anyways. Next, I would drain and flush the entire cooling system. Drain out the coolant, stick a hose in the thermostat housing, run the car with it on until the draining coolant is just water, and then refill properly. Make sure the heat all the way on and on full blast while doing this.
One winter I had a busted thermostat and the car would never warm up to full operating temp. Sucked because it was a cold winter, and the heater will only blow cold air because of it.
As far as the noise... not too sure. If you're feeling it in the pedal, it sounds like suspension work. Can you hear any noise when the engine is just idling?
Lastly, what year/model do you have?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-04-2010, 12:20 PM
Originally Posted by david-b View Post
Welcome to AF!
Thanks for the reply. I do not hear any noise when the car is just idling. I only hear it when the car is working hard (ex. higher rpms, uphill driving, high speeds). It sounds almost like I'm constantly running over small bumps on the road. I don't know if it is actually located by the accelerator or not. I just know I can feel the knocking/tapping vibration on my foot when it occurs and it's usually when I break the 45 mph mark. I thought the two symptoms (engine running cold/knocking) may be related since they both occurred at the same time, but it could also be a coincidence. My car is a 1998 Mitsubishi Eclipse RS.
Old 10-04-2010, 02:09 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
If the car is running cold the thermostat could be stuck open. If it was closed the car would overheat. It could also be the temp sensor for the gauge has gone bad.
As for the knocking does it make the sound when just free reving?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-04-2010, 03:38 PM
No it is only making the sound when the car is actually driving.
Old 10-05-2010, 06:08 PM
Holset powered 420a
Hopefully its not a spun bearing. Could drain the oil and check for metal shavings or it could be something loose on the motor or suspension area. Try and narrow the area down where its coming from if you can
98 Eclipse GS Turbo
2001 BMW 325i - DD
Engine running cold scoteric Park Avenue 21 01-27-2010 11:46 PM
Engine running cold TGENERAL Escort 4 03-14-2007 02:55 AM
99 Metro engine runs Cold-Warm-Cold-warm KuzinKatie Metro 1 01-28-2006 07:06 PM
Engine runs cold in the winter thedriver85 Engineering/ Technical 1 03-24-2005 10:15 PM
94 poor mileage-running cold and rich galloopee Ranger | Courier 0 01-14-2005 07:54 PM
