Old 10-03-2010, 09:32 PM
02 Windstar 02 Windstar is offline
Airbag code help!
My airbag light on my 02 Windstar is flashing one then 9. I am assuming by other posts that this is a 19. Does anyone know what this means? I can't find info on code 19 anywhere.
Thanks in advance.
Old 10-04-2010, 10:31 AM
catvents catvents is offline
Re: Airbag code help!
Thanks in advance.
This diagnosis lamp fault code #19 refer to "driver front airbag circuit fault"
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
Old 10-04-2010, 03:34 PM
Does that mean it's something in the electrical? Any suggestions on where to go to dig in further? Or somewhere to help with diagnostic of that circuit?
thanks
Old 10-05-2010, 03:38 PM
phil-l phil-l is offline
I suspect you may have problems with the airbag clockspring, which is a mechanism that creates a consistent electrical connection to the airbag throughout the steering wheel's full range of motion.
Search eBay for "windstar clockspring" for pictures of what your clockspring looks like.
There are a number of useful YouTube videos on this topic. Two I quickly found:
Test a clockspring: http://www.youtube.com/watch?v=-UgL22uM8Tk
Replace a clockspring: http://www.youtube.com/watch?v=XB-qHTVWCSQ
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 10-05-2010, 10:20 PM
Ok I'll test it. In all I've read about clock springs it sounds like either the horn doesn't work or the cruise control doesn't work when the clock spring is out. Both work ok on my car.
Also do you know if I can reset the light myself after the repair?
Old 10-06-2010, 11:37 AM
Yes, modern clocksprings also carry the signals for other steering-wheel mounted controls. But they're handled separately in the clockspring - they may be fine even if the airbag portion is failing
Also note that you probably won't notice if your horn or cruise control have an occasional, intermittent open circuit. However, that poses a big problem for airbags - they need to be ready to function at all times, and deploy in the precisely correct fraction of a second. The airbag controller is designed to sense any such problems in the signal path, and report them.
While I don't have Windstar-specific airbag controller knowledge, I believe most airbag controllers will reset when the battery is disconnected for a short time. Of course, resetting the controller does little good of the underlying problem hasn't been addressed.
1995 Contour GL 2.5
Windstar airbag codes olopezm Windstar 2 07-11-2010 05:04 PM
06 Commander airbag light? hagdad Commander | Patriot 1 02-28-2010 06:50 PM
02 windstar airbag code 51 pls help fetchitboy Windstar 0 02-22-2010 12:56 AM
drive side airbag resistance too low - airbag light on cluster error code bratt Beetle - New/New Beetle Convertible 1 08-24-2008 10:58 PM
Airbag Code B1942 HELP! laj130 Windstar 2 02-14-2007 04:56 PM
