Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-03-2010, 09:57 PM
Boldorff23 Boldorff23 is offline
1998 Olds 88 power windows quit working
Hi, Im a new poster to AF, been looking here for help for a couple years. Here is my problem. Just bought a 1998 Oldsmobile 88 recently and the windows quit working. They worked the night i brought the car home and 2 days later when I went to go to work they wouldn't go down. None of the switches for the windows work. Checked fuse boxes but couldn't find anything for windows, the circuit breaker under the hood is still good according to my cheapo tester. I replaced the switches in both front doors. Those were the only ones used when we brought the car home. I have power to everything else in the car except the windows. Used a tester to check for power to drivers door switch and have nothing. Any help or incite would be greatly appreciated. Thank you.
Old 10-03-2010, 10:35 PM
old_master's Avatar
Advisor/Moderator
Re: 1998 Olds 88 power windows quit working
On the driver door switch: all wires should show less than 5 ohms resistance to ground EXCEPT the pink wire, and it should show battery voltage with the key in the accessory and run positions. Check the owners manual for the fuse/circuit breaker location and make sure it's good. A common place for wires to break is in the rubber boot that goes from the "A" pillar to the door. The wires usually break inside the insulation so at a glace the wire appears to be ok.
You have to know how it works,
to figure out why it doesn't.
Old 10-09-2010, 11:42 AM
Jrs3800 Jrs3800 is offline
On both the drivers and passenger side, there is a Ground Strip with the wiring harness... The drivers side is as far left as you can go attached to the wiring harness, on the passenger its a far right as you can go.... Both are under the carpet in the foot well... Remove and clean the Ground bars and see if you get you power windows back..
Quick question tho, did you lose anything else?
Old 10-09-2010, 03:23 PM
@Old_Master-Thank you for the help, havent gotten a chance to try it yet. Ive been working too much.
@Jrs3800-Thanks for the tip. No every thing else works. Power seat and mirrors and locks all work like they should. The only thing that I'm not sure of working is the radio being that when I got the car it didnt have one in it and I havent had a chance to go get a cd player and wire it in.
87 G20 Power Windows quit working..Help Please garcam123 Express | G Van 1 07-25-2009 07:27 PM
01 Suburban Driver Power Window quit working alycat Suburban 0 07-22-2007 12:43 AM
1998 Taurus power steering quits working ragman60 Taurus | Taurus Wagon 6 11-01-2005 08:01 AM
96 civic power windows quit working marsh67 '96-'00 Civic 2 04-11-2005 08:43 AM
Power Windows Quit Working But Not The Regulator DREAMWILLOW Grand AM 2 08-13-2004 10:44 AM
