Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-02-2010, 10:00 PM
v45willy v45willy is offline
Question CONFUSED!!! 22re timing/distributor
(1986 22RE,) #1 CYL TDC CAM IS @ 12:15 BY MARKING ON GEAR,, DIST. IS POINTING TO #3 CYL. CRANK IS AT 0>> TURN CRANK 1 COMPLETE TURN,CRANK IS AT O, TDC #1 CYL. IS @ 11;45 by MARKING ON GEAR,, DIST. IS POINTING TO #2 CYL. . hELP ME UNDERSTAND THIS SIMPLE EQUATION "I CANT SEEM TO AEE THE FOREST FOR THE TREES" i NEED CRANK IS AT INPUT I AM IN THE MIDDLE OF THIS JOB.. THANKS
Old 06-20-2012, 08:25 PM
Maintman900 Maintman900 is offline
Re: CONFUSED!!! 22re timing/distributor
Hey man, I was working on a 22RE tonight with my bosses Dad, Hie cam was at 12 o'clock and his crank was at 6 o'clock and #1 piston at tdc and had to move hie dist around a notch, you put it in at 12 o'clock and it will go ccw about 35 degrees, should land centered on #1 plug under dist cap. Goodluck.
Timing Adjustment Question JAGSARGE F Series 4 05-31-2010 04:50 PM
2002 Distributor Install Procedure wmako M Bodies 2 02-02-2010 09:16 PM
22re timing promblem [email protected] 4Runner/GX470 2 07-07-2008 08:02 AM
22RE timing chain walstib7 Pick-Up 19 11-15-2005 01:56 PM
22RE Timing - 1994 scrap_iron Pick-Up 2 04-08-2005 04:19 AM
