p0171 & p0174, or was..
So i had p0171 & p0174 but the car ran fine. Maybe a bit less power, but its kind of hard to tell if I had some with such a small engine
Anyways, I ran some seafoam through the engine and that cleared the p0174 code, but I still get the p0171. I cleaned the Maf which made the SES light come on 50ish miles later than normal, but after I cleaned it again, I did not have as much luck. Any thoughts? I'm pretty such its not a vacuum leak. Also, one more thing is that I have a very serious loss/lack of power when I start in cold weather for about 25 yards or so.
Re: p0171 & p0174, or was..
FSM says P0171 is: Mixture too lean. Possible causes:
intake air leaks front O2 sensor bad injectors clogged/not working exhaust gas leak incorrect fuel pressure lack of fuel MAF sensor check easy things first like fuel pressure, fuel filter. Hope this helps. |
