Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 10-01-2010, 07:15 PM
chevelle ss 396 chevelle ss 396 is offline
Question need help rear end axle problem
I have a 1969 chevelle 12 bolt. I put in a new eaton 4 series posi carrier with timken bearings and yukon 30 spline axles. the problem is the axles just spin in the carrier. I bought the carrier on line and was told it was a 30 spline unit. I am wondering if it is possibly a 33 spline and that is why the axles spin. Is there a way to check the spline count with out taking it out of the housing?
Old 10-01-2010, 09:31 PM
Blue Bowtie's Avatar
Registered Offender
Re: need help rear end axle problem
It may be impossible to see the side gear when they are installed. The best way to check fit is to remove a side gear and axle and observe the fit.
Did you inspect the carrier and diffy when it was out?
Old 10-02-2010, 12:25 PM
I bought the posi carrier as a 30 spline unit and I bought 30 spline axles so I didnt think I would have to pre fit. I talked to the tech people at Eaton and they said some aftermarket companies sometimes put 33 spline gears in their units so I was wondering if anyone else had come across this. My axles are not bolted in yet because when the c clips were going to be put on there was deffinately a problem.
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
Need help..... rear end noise swampmoose Tahoe 8 02-13-2008 08:28 PM
Help...Rear Diff. Axle Seals/ 2000 GrandCh. LynetteD Grand Cherokee | Grand Cherokee SRT8 2 08-11-2007 08:53 PM
ok...I need rear-end, axle help... instantkevin F-Body Problem Diagnosis 14 01-04-2007 03:54 PM
'97 Rear Brake / Axle Problems enigmabird Thunderbird 0 08-02-2006 01:18 PM
