Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-30-2010, 10:07 PM
jjakspaw6 jjakspaw6 is offline
possible oil presure problem
Hi All,
I'm new to this forum. And I am not much of a mechanic so bare with me...
I recently inherited a 95 passport. the truck sat for about about a year due to a horrible oil leak coming from both valve covers.. before I got it. i had the gaskets replaced this week. and besides a little smoke from the spilled oil but its not leaking anymore. the engine (according to the previous owner) has had a tick since he got it at 80k. it has 222k now and still seems like it has the power of a new engine.
the mechanic that replaced the gaskets, tells me that the engine is loosing oil pressure possibly from clogged pickup or a failing oil pump and that due to the high mileage, he recommends replacing the engine. why replace the engine it I can dry spin the tires when barely stepping on the gas?!?!?!
The mechanic did not do a manual pressure test and is going by the oil gauge... The gauge will sit between 0-85 for about 15 minutes after driving then it starts to bounce around... all the way down to 0 and all the way to the max (100 i think)...
it doesn't seem to be over heating.. I think the ticking may have got louder as i drove it but it was really hard to tell seeing i was on a busy highway from the shop to my home.
I haven't driven the truck for more than a few minutes so far. so i can really elaborate more than the mechanic has told me. and the little bit bout the ticking.
I would like to try and clean the engine and if there is a way, I want to clean the pickup screen (if it is not too difficult like removing the pump) I read a little bit about seafoam engine cleaner. would this take care of the possibly clogged pickup?
does anyone have any suggestions?
Much appreciated.
Jason
Old 09-30-2010, 10:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: possible oil presure problem
I recently read a post that the low oil pressure on his truck was due to a plugged oil filter.
I would probably spin off your current filter, put on a new one. Dump in 1/2 a can of sea foam and then go for a 15 mile ride. Then dump the oil and change the filter and see what happens...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-30-2010, 10:42 PM
Sounds like a good idea. the filter is new... oil was changed when the shop replaced the gaskets.
might be worth the shot.. lets see .... $30 compared to $1800....
98 5.9 oil presure problem modman84 Grand Cherokee | Grand Cherokee SRT8 2 11-26-2008 10:54 AM
88 Toronado Oil Presure Problem Kremer210 Toronado 7 07-14-2006 03:54 PM
oil presure problems 91_T-Bird_HO_5.0 Thunderbird 2 06-02-2004 11:40 PM
possible oil pump problem ,slow oil pressure on cold engine 71chevydude C/K 0 03-22-2004 04:11 PM
eratic oil presure problem TomM11223344 Ram Pickup | Ram SRT10 3 01-15-2004 11:30 PM
