Old 09-28-2010, 10:13 PM
swampie swampie is offline
92 Buick Park Ave Oil Change
How much oil does my 92 park ave take when I am changing it. Also where is the fuel filter located thank youu (;
Old 09-28-2010, 11:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 Buick Park Ave Oil Change
I assume, you are planning to to change the filter; (which is common practice) and if so, add 1/3 qt to the new filter and 4+ qt to the crankcase & start the engine & let it idle for 1-min, then shut it off. Wait for another 2-min & check the oil level with the dipstick and add oil if required to bring it to the full mark.
The fuel filter is located near the right front tire, inside & slightly above front frame rail.
Old 09-28-2010, 11:13 PM
thank you. i do also plan on changing the oil filter too. thank you it was a big help
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
'95 Park Ave OBDI port location? GMLoyalist Park Avenue 2 04-14-2009 12:57 AM
3.8 buick park ave buick wanting to die Dsmith362003 LeSabre 3 12-22-2004 12:02 AM
1991 buick park ave. aztinman General Discussion 0 09-02-2002 07:57 AM
Programing 96 Buick Park Ave steveace General Discussion 0 06-12-2002 12:51 PM
