Old 09-28-2010, 10:12 PM
baron1701 baron1701 is offline
02 Alero w/ 2.2 Ecotec Transmission Mount
Hi, how do you replace the Passenger side Transmission Mount? I have done the upper Drivers and the Passenger lower rear bit I am scratching my head looking at the main transmission mount. The mount goes into the wheel well and I dont see a way to remove it. Any help would be appreciated, thanks.
My alero has 193k and has been experiencing terrible vibrations for the last 50k or so that got a lot worse as time went by. I narrowed it down to the mounts. After doing two of them there is a huge difference.
Old 10-07-2010, 06:30 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 02 Alero w/ 2.2 Ecotec Transmission Mount
If we are thinking of the same one, there are bolts accessable inside the wheel well with a long 3/8 extension. While its off it may not be a bad idea to change the belt.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-07-2010, 10:17 PM
Ok, very easy to do. I only had to put the car on a jack and pull the tire to figure it out. I think I way over thought this one. Be carefull with the top right bolt as it hits the brake lines while pulling out. I found that the geared 18mm wrench (one with socket like action) was the only way to get the top out from the bottom. It wasnt until I was done and checking the vibration with the new mount that I figured out how to really do it right.
If you pull the air box out there is a ton of room and its very easy from the top.
1997 Chevy S10 2.2 Starts Then Dies Logan76 S-10 9 07-29-2010 04:44 PM
trooper 1993 3,2 Dohc , automatic transmission change windfast Trooper | SLX | Bighorn | Wizard 0 04-26-2010 01:21 PM
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 08:21 PM
no start 95 cavalier 2.2 jeffyweasel Cavalier Problem Diagnosis 2 03-14-2009 07:12 PM
2.2, 2.4 TC and 2.2 ECOTEC Nitroustang Cavalier 28 04-06-2004 01:25 AM
