Old 05-20-2003, 08:56 AM
jalfaro jalfaro is offline
Parking Brake indicator came on while driving
Yesterday it was raining and all of a sudden the parking brake indicator on the dashboard came on. I checked to see if I didn’t leave the parking brake up a little and it wasn’t. Then I saw that every time I pressed the clutch to change gears the light would turn off and then back on when I released the clutch. I got home turned off the car and it hasn’t turned on since. Only when I apply the parking brake, as it should be. The last time this happened (7-8 months ago) it was raining cats and dogs, just like yesterday.
Is there any relation between the clutch and the parking brake for that to happen?
Me clutch is hydraulic not cable.
What kind of short could it be?
Has this ever happened to anyone?
Thanks for the help.
Old 06-20-2003, 11:22 PM
icechopper26 icechopper26 is offline
This may indicate that a brake light has burned out. Have someone check you brake lights while stepping on the brake pedal.
Old 08-05-2003, 08:18 AM
micheal micheal is offline
Send a message via AIM to micheal
r u sure u haven't been e-braking wayy to much and your car is just confused - lol.
Old 08-05-2003, 09:17 AM
BullShifter's Avatar
low brake fluid will also cause the light to come on. when the brake fluid is low, that usually means the pads/shoes are worn.
Old 08-05-2003, 10:48 AM
HONDA_99 HONDA_99 is offline
yeap, just jackasssi said, your brake pads and rotors could be worn out and caliper pistons are out far enough for brake fluid to drop in reservoir which would bring brake light on.
chech condition of pads and rotors and if they in acceptable condition just brake fluid.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
'95 Infinity J30 Parking Brake Indicator voldemort Cedric | M45 | J30 | Gloria 9 09-12-2010 06:44 PM
Parking Brake indicator on 97 civic - controller issue? drew3007 Let's get Technical! 4 07-08-2006 11:28 PM
Park brake indicator on acceleration drew3007 '96-'00 Civic 2 02-19-2006 01:31 PM
Parking Brake Indicator Light Problem jaegerbiker Intrepid 5 11-12-2004 07:50 PM
96- Parking Brake indicator comes on while braking (when car is moving) muzztard Taurus | Taurus Wagon 2 11-01-2004 10:23 AM
