Go Back   Automotive Forums .com Car Chat > Ford > Econoline
Old 09-27-2010, 11:52 AM   #1
tbakko
High temp but no overhating
I just bought a 1987 Ford Tioga Motorhome on a Ford E350 Chassis. When running the vehicle the temp gauge runs on the letter L in normal, which is just about to the upper mark in the normal range. When going up a moderate hill the needle only moves about 2 needle widths then comes back down when you top the hill, it never goes past the normal range. When I turn the heater on, the temp rises & will continue to the hot mark but as soon as I turn the heat off, it goes back down into the normal range, it does the same thing if I turn on the air cond. Any help will be appreciated. Thanks, Tom
tbakko is offline   Reply With Quote
Old 09-27-2010, 07:22 PM   #2
rhandwor
Re: High temp but no overhating
I would talk to a radiator shop about having it cleaned and having a rod run through it then boiled out.
Use a water hose and disconnect both heater hoses flush out the heater core.
rhandwor is offline   Reply With Quote
'92 XFi: intermittent high idle + high temp SchlockRod Metro 5 01-16-2009 10:24 AM
3sgte.engine very high temp but 1/4 gauge reading bo nada Celica 6 05-30-2006 07:00 PM
95 Grand Prix Temp Guage OVERHEATING what to do RavenGp Grand Prix 8 12-26-2004 12:52 PM
No Low Beams or high beams, but high flash sn95 Taurus | Taurus Wagon 0 06-10-2004 12:14 PM
high temp. thermostat vs. low temp. thermostat amyindallas Cutlass Series 1 06-07-2004 11:31 PM
