Old 09-26-2010, 05:28 PM
C.Steele C.Steele is offline
"Chirp" when taking off from stop. Something slipping?
I have a 2000 Silverado 1500 4x4 with a 4.8L - Automatic trans
When I take off from a stop I sometimes hear a "chirp" like something is slipping or rubbing metal on metal. It sounds like a big sound not small if that makes sense. Kind of a hollow metal rubbing on metal sound. Best I can describe it.
When I pull my boat it does it all the time. When not towing it does it maybe 40-50% of the time. It sounds like it's coming somewhere from the center to the rear. Definitely not the engine or front area.
I have looked underneath and I don't see anything obvious. Does this sound familiar to anyone? Looking for ideas of where to start narrowing things down here. U-Joint? Rear end (please no)? Suspension?
I have no clue where to start looking. Thanks for any advice.
Chris
Old 09-26-2010, 07:19 PM
777stickman 777stickman is offline
Re: "Chirp" when taking off from stop. Something slipping?
Are your rear brakes drum or disk? If drum you may want to look there 1st. U-joints could also be an issue.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-26-2010, 10:21 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Prob the slip yoke....
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 09-27-2010, 09:28 AM
denco denco is offline
My 2001 has done this since new.
Mine also has a clunk from the drveshaft, pop from the muffler and ticking engine.
Love it!
Old 09-27-2010, 10:03 AM
I did see a TSB online about the slip yoke producing a "squawk" when taking off from a stop. Maybe that is it.
Is there a way I can check this? Is it possible it just needs lube? Is it something I could do myself?
I know nothing about a slip yoke. Matter of fact I'm not even sure where it is. I think it's at the end of the drive shaft coming from the transfer case? Thanks for any info.
Old 09-27-2010, 12:11 PM
j cAT j cAT is offline
I had this problem of slip yoke sticks and when starting from a stop especially when still cold . this was corrected back in 2003 on my 2000 5.3L 4X4 , when the dealer under warrantee replaced the tracII transfercase fluid.
since that time I replace this fluid and the transmission fluid every 30-40,ooo mi . the clunk has not returned and 10yrs with over 125,ooomi no failures or leaks.
trac II transfercase fluid is "only" at dealerships. If you have some lube jocky do it they can destroy your transfercase with the wrong fluid.
Old 09-27-2010, 12:51 PM
kahjdh's Avatar
I did the flush and it didnt work, had to put the nickel plated yoke on.
Current Cars:
Past Cars:
Old 09-27-2010, 02:32 PM
COULD BE the one that was on there was worn.
my clunking yoke was only at 30,ooomi .....
I knew it was the yoke cause I could spray the drive shaft with wd-40 and it would go away for a few weeks then come back..
Old 09-27-2010, 10:23 PM
kahjdh's Avatar
yea, I bought mine with 94k on it already.
I tested it by taking the driveshaft off and drenching the yoke in auto trac then taking a test drive. Was quiet for a few miles so knew it was it.
Current Cars:
Past Cars:
Loud noise/thud at take off from stop dmbland Rodeo | Passport | MU 5 11-11-2006 10:56 PM
Rough idle and misses sometimes when taking off from stops. DanMan7 Metro 13 10-19-2006 10:53 PM
Popping sound when I take off from a light and stop jsledge Blazer 15 04-06-2006 05:36 PM
635csi /heat when stoped / cold when take off jazzfor3 6 Series 1 01-22-2005 08:50 PM
