Old 09-26-2010, 04:31 AM
engineblock engineblock is offline
Mounting body over a spaceframe chassis ?
I am currently working on a fuel efficient car project and we have a spaceframe chassis built with a glass fibre body separately created for it. Now I am analyzing the ways of mounting that body over chassis, what ways would be best ?
If a slot could be built inside body then a chassis member can be made to sit in that housing holding the body. It's one way I thought but not much sure if the slot could be built inside body. What other type of strong mountings can be made.
Suggestions & Opinions would be really appreciated !
Regards
Old 09-26-2010, 10:38 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Mounting body over a spaceframe chassis ?
A friend of mine did exactly this a few years ago. He used a Formula Ford race car with a custom made one seat fiberglass body on it.
The body should be insulated from the chassis (rubber mounts are best) or else the vibration may crack the fiberglass over time. Take a loot at a typical pick-up truck. Look underneath. You will see the body is bolted to the frame. The bolts go through these rubber biscuits, so the body actually sits on rubber. This rubber allows the frame to shake and vibrate a bit without harming the fiberglass.
You may be able to engineer a similar arrangement for your project.
Old 09-26-2010, 01:31 PM
Thanks for the response. I felt we can get the idea from truck as I saw some mountings patented for trucks infact. The chassis member can be bolted to the rubber mounts fine, how will those rubber biscuits connect with the glass fibre body, that's what's puzzling me
Old 09-26-2010, 09:11 PM
RahX RahX is offline
The biggest thing is frame flex vs body flex. If there is a big difference, usually the body will crack. The easiest way to eliminate this is to have some sort of mount that buffers the flex.
Engine Mounts williamjbronski LHS 2 01-29-2011 06:07 PM
Replacing the struts & strut mounts Jmalbright Alero 8 03-15-2010 10:21 AM
Metro Auto Trans Mount FUBAR ManicMetro Metro 1 01-11-2010 09:15 PM
Pass Motor Mount Plate - Stuck... pyro4329 2nd Gen 00-05 1 11-08-2009 03:22 AM
E46 Body Panels / E36 chassis BuiltM3 M3 0 10-07-2002 06:27 PM
Tags
body , chassis , efficient , fuel , spaceframe
