Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 09-25-2010, 12:32 AM
Glenalth Glenalth is offline
Accelerator pump repair
Info: 1984 B250, Slant 6, Holley 1945
I've been having an issue with sudden acceleration and have been given advice from multiple people that it is likely the accelerator pump. A quick look down the carburetor shows no fancy stream of fuel when the pedal is floored or when the pump operating rod is manually operated. Looking at manuals and diagrams that I've found, the pump piston cup or spring seem like the most likely parts to have worn out. I'm not seeing these parts for purchase except as part of rebuild kits.
Since I'm having to pull it apart to get at those parts anyway, do I need a full rebuild kit for replacing gaskets and such or do I need to hit up some specialty vendor for the individual parts instead?
Anything else I will end up needing beyond basic tools if I end up doing a rebuild?
Old 09-25-2010, 11:54 AM
alloro alloro is offline
Re: Accelerator pump repair
Just get a rebuild kit. They have everything you need (including an exploded diagram) and usually cost less than $20.
Old 10-07-2010, 01:13 AM
Holley rebuild kit is on the way, now I get to see if I fix it or totally screw it up.
Old 10-07-2010, 08:57 AM
For a trouble free rebuild, I recommend a 2'x2' clean work area, a can of carb cleaner, and a small plastic bowl to hold small screws and ball bearings. Take your time, make some diagrams or take pictures, as you're disassembling it. Most important of all, clean everything extremely well.
Old 10-10-2010, 03:48 PM
Everything is back in and working better than ever. Idle is smoother, more power on hills, accelerator pump is spraying again, even spun the tires a bit. Not sure how much of that is new parts and how much is just having everything cleaned out.
Looks like somebody rebuilt this in the past and put a spring on the wrong side of a retainer clip on the rod for the accelerator pump. It was just between the clip and end of the rod, not putting any pressure on anything. Moved it to the other side of the clip so now the rod springs back when it is released.
The Holley kit came with a cardboard tray that worked to hold all the little bits. Ended up using part of the box to poke screws through and write the matching part number from the diagram that came with the kit. Overall it was mostly painless (other than the hour+ it took me to get the pump rod grommet into place), just took some time.
Was checking out all the attached hoses and discovered a broken hose leading directly to the EGR amplifier. Taped it back together until I can get a replacement hose. Found a lot of cracks/breaks in hoses where they connect to the vapor canister. Looks like I found my next project.
Old 10-10-2010, 04:20 PM
Nice going, now you're the neighborhood carb rebuild pro!
Old 10-10-2010, 04:30 PM
It might come to that. There are two other vehicles out here that are having issues with fuel flow that I have been voluntold to diagnose/repair. Both will probably end up with more trips to the forums here.
E150 XLT Power Hesitation During Acceleration! leroge Econoline 2 02-28-2010 07:46 PM
1986 Trooper Accelerator Pump Piston Leaks TrooperBill Trooper | SLX | Bighorn | Wizard 2 11-17-2009 01:11 PM
Bed Removal For Fuel Pump Repair jhenry240 Problem Diagnosis 12 03-08-2009 09:27 AM
ABS Pump Repair, 99 Silverado strmh Silverado 1 10-18-2004 10:31 AM
How much is the air pump repair? - Code P0410 hcary Blazer 1 11-30-2003 09:15 AM
Tags
1945 , 1984 , b250 , holley , slant6
