Old 09-24-2010, 05:23 PM
dan fitz dan fitz is offline
88 F250"rear antilock" light on
have been driving this beast for a number of years and since we got it the dash has had this "rear antilock" light on. is this about antilock brakes or is it something to do with limited slip differential ? and do i need to be concerned that it's been on, am i missing something that i'll wish was working in a high speed stop or what.... any thoughts appreciated.
Old 09-26-2010, 05:50 AM
rhandwor rhandwor is offline
Re: 88 F250"rear antilock" light on
Some of these have a switch back by the frame in the rear. Try bleeding a rear brake bleeder and check if the light goes out. You can also try disconnecting the battery for 3 minutes.
If you have full time anti lock go somewhere and have the codes pulled.
Old 09-26-2010, 07:02 PM
butch h butch h is offline
There is a sensor mounted in the top of the rear axle housing. This is supposed to activate the RABS module (anti-lock unit) when conditions are such,that rearwheel lock up is imminent. There is a test connector under the hood,drivers side (at least on my '96 250 there is), that is used to flash the anti lock light. The number of flashes should point you in the direction,as to what the problem is.
Old 09-26-2010, 08:28 PM
jyount jyount is offline
The rabs on these trucks sucks even when it works. They are not modulated antilock like the new setups are. They are a dump valve only, completely not safe to say the least. If it senses a lock up is eminent its response is to "dump" rear brakes completely. I don't know what they do when the light is on, but if it works like standard brakes, take out the light and modulate it with your foot like the old school, safer anyway.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 11-18-2010, 08:08 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Mine was on for a while off and on found out it was the wire harness that plugs into the brake master cylinder and i replaced the wire harness with one used from the yard and spliced it in NO MORE LIGHT ON
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Dash Lights & Battery Light LilBitEG Explorer | Explorer Sport Trac 2 09-10-2010 06:47 AM
96 PA indicating lights Knox cnty resident Park Avenue 0 07-08-2010 01:03 PM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
