Spongy brakes
I have a 99 Tahoe that I really like and plan on towing a small travel trailer. It has the tow option and everything, but I am concerned about the brakes. We had the brakes checked at the Ford dealership that we bought this at and then again at the local Chevy dealer (to the tune of $58.00) and everybody has said the brakes are fine but to me they feel spongy and sometimes they have to go almost to the floor to stop. I am not at all comfortable with them. I have looked at some of the aftermarket kits for rear disc conversion..but thats over $1200 not including labor. Any sugestions?
Re: Spongy brakes
Any brake lights on?
Will brakes slide all 4 wheels? First test is engine off pump brakes a few times to remove vacuum from booster. Then step on brake and see if you have a good full pedal. Post back on that. Rear disk brake will not help much. Most breaking is on front wheels.
Re: Spongy brakes
No lights on and the vehicle has ABS so I didn't try to lock up the wheels. I did pump up the brakes with the engine off and the pedal got nice and firm. Thanks
Re: Spongy brakes
OK if firm pedal up to the top with engine off says front and rear brake hydraulic system and adjustment OK.
In first post on pedal going almost to floor does it do that all of the time or part time? Can you feel any pedal drop or seep down with light brake pedal apply light sitting at stop sign with in gear? Any brake fluid lose?
Re: Spongy brakes
If so this problem is quite common. the pro's that are experts at these brake systems for some reason don't get it with why this occurs. the drums made in todays world are of much softer metal[this wears down faster]. the use of brake shoes not using the ASBESTOS lining material , but a highly abrasive mix , adds to the problem. replace the rear drums. since you towing a trailer , you will need to replace these drums at every time the shoes are worn. when the drums are removed look at the top radius of the shoes. If this is worn but the bottom radius not worn much ,this is the drums worn or bell shaped from overheating.............. NEVER EVER CUT DRUMS ! |
Re: Spongy brakes
No loss of fluid..and the brakes seem to go to the floor only part of the time. It will hold the pedal with light pressure at a full stop in gear. I'm beginning to think who ever did the brake job last took the cheapest way possible and bought junk pads and shoes.
Re: Spongy brakes
Cheap wil not stop good but should not lower pedal.
As J cat said rear shoe or drum wear may lower pedal. But that part of time is not right. Part of time with no fluid lose could be in master cylinder or air in system. Has the brake system and ABS system been bleed good?
Re: Spongy brakes
spongy brakes mean air in the brake system. when braking normally if the brake effort is lacking , replace the rear drums if as I mentioned , the top of the shoes are only worn. since you had this inspected and paid for this inspection something is very wrong here............... shoe/pad quality is not a factor with you complaints............ |
Thanks to all that gave me their advice...I know when the brakes were looked at at the ford dealer, they said the shoes were at a 4 and they replace them at a 3...I doubt if anybody miked the rear drums to see if they were still in spec so if I put new drums and shoes on the rear is it worth the extra dollars to put performance parts here? I will also have the brakes and ABS bled at the same time. Any recommendations for parts ? I have been pretty much out of the loop for a while so I am looking for some good feedback. Thanks
Re: Spongy brakes
Re: Spongy brakes
Spongy brakes are a common problem with this truck chassis. From what I've read and from limited experience, you can bleed them till the cows come home and still have spongy brakes.
To be 100% sure, the ABS system needs to be cycled using what's called a Tech II scanner to remove all air from the unit by cycling all the ABS solenoids to dislodge any air bubbles. Second, do the old, two-man brake bleed or the one man with the hose bubbling into a jar of fresh fluid. I've found that I can't get a good tight seal around the bleed screw to do a good vacuum bleed, but other setups may vary. DO NOT LET THE RESERVOIR GO DRY! Three, adjust the rear brakes properly. Even though the rears don't provide the majority of the stopping power, they do engage first to give stability to the vehicle, the proportioning/combination valve then works to adjust the front/rear pressures. If these engage late due to them being too loose, then it can feel like braking is delayed. Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Re: Spongy brakes
This should help you out quite a bit...invest in a good set of new pads!!
Pads - Check out Hawk LTS - they are "thicker", therefore the brake pedal travels less before the pad touches the disc. Discs - you can also invest in slotted rotors - don't go Chinese and no need for cross-drilled. Stainless Steel Brake Lines - some people have noticed firmer pedals going this route, but i personally can't see how a set of Stainless lines would be better then a new set of rubber (the whole expansion theory). Net Net - new pads should give you the best bang for your buck. Check out this link: http://www.tahoeyukonforum.com/forum...highlight=hawk They also discuss the upgraded 3/4 ton caliper. Hope this helps. |
Re: Spongy brakes
So when my brakes pads wear down, my pedal travels more? I don't think so.
'92 s-10 4x4 EC p/u '99 Blazer LT '99 Suburban LT |
Re: Spongy brakes
Then add your insight as to why premium pads require less pedal travel then cheaper pads.
Re: Spongy brakes
when I had to brake very large transportation vehicles I used a pressure supplied bleed machine. the guages told this story quite well. these toy trucks/vehicles weigh 5,ooolbs..when you bleed brakes for 50,000lbs you must not make stupid mistakes and ignore worn braking componets. |
