Old 09-23-2010, 10:29 AM
tuckerman22 tuckerman22 is offline
95 Buick Lesabre A/C compressor bypass pulley
Hi All,
I’ve looked high and low for a thread on just bypassing the A/C compressor and have had no luck finding one so here it goes. The compressor locked up (bearings) on my son’s car 95 Lesabre and completely stopped the started from rotating the engine. Instead replacing the compressor I opted to remove it and install a bypass pulley. This was a pretty strait forward process but when I started the car I had a check engine light so I had it scanned and had the following codes:
P1640 QDM1 failure P1670 QDM4 failure
P1406 EGR valve pintle position circuit
This is my son’s car and he can’t remember if the ck engine light was on before the A/C compressor locked up. So, my question is did removing the A/C compressor from the wireing harness cause these codes? If so, do I have to jump the compressor wires? If the codes are not a result of removing the compressor what do you think it could be?
Old 09-23-2010, 12:43 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 Buick Lesabre A/C compressor bypass pulley
Welcome to AF. The pcm sees an incorrect egr position based on it's commands, so it could be bad or carboned up egr, the quad driver controls high load solenoids, I do not believe the a/c has anything to do with these codes, you will need a comprehensive wiring diagram to see what quad driver 1 and 4 controls. Just make sure the are no obvious pinched shorted wires anywhere around under the hood.
Old 09-23-2010, 07:22 PM
big white bufflo big white bufflo is offline
doorman makes a bypass pully for this application i did my 92 and it works great look at rockauto and try napa or autovalue for this part and i just left all my wires hangging with no troubles
1997 Buick Lesabre randomly Dies (Electric) MikeTwoJay LeSabre 2 04-16-2009 08:37 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 06:49 AM
1997 lesabre a/c compressor bypass? StewartFan20 LeSabre 5 06-28-2008 05:30 PM
1992 Chevy Astro van AC problems and compressor bypass pulley nc76 M Bodies 4 12-14-2007 02:02 AM
3.1 ac compressor bypass pulley JobeSmith Grand AM 0 03-06-2007 08:53 AM
Tags
a/c , codes , qdm1 , qdm4
