Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 09-22-2010, 06:52 PM
Glewis12505 Glewis12505 is offline
1994 APV fuel injectors wont spray
I have a 1994 apv, it ran great but had an oil leak, so i decided to do a tune up, bad idea! I changed plugs and wires, and removed distributor to replace o ring to stop oil leak, removed with #1 DTC. reinstalled everything worked great and ran well, drove to town and back parked it went out this morning and would not start. I have spark at all plugs, fuel to throtle body and hot not both injectors, but injectors will not spray, it will run while manually pouring in gas...im pretty good with auto's but not sure why injectors would quit after tune up. what am i missin? Thanks in advance lew
Old 09-26-2010, 10:13 AM
DAB77 DAB77 is offline
Re: 1994 APV fuel injectors wont spray
you need to get a noid light and test for injector pulse. If you have someone to help you, you can use a regular test light..If you have pulse then you either have bad injectors or not enough fuel pressure. If you donot have pulse then you could have a problem with the wiring,injector drivers or you may have something loose or broken in the distributor
Old 09-29-2010, 02:41 AM
LMP's Avatar
LMP LMP is offline
www.avigex.ca/xport/fuelcontrol31.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
2003 Mustang GT - Injectors & MAF?? ndean52 Performance 1 05-03-2010 12:26 PM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 06:33 PM
92 APV fuel injector causing engine to die AJ&J Lumina APV 8 11-04-2007 07:35 PM
1994 Caprice Fuel Injectors test Musician423 Caprice 1 12-04-2006 08:27 PM
