Old 09-20-2010, 12:34 PM
mickfoely mickfoely is offline
Question Need to pass emissions test
Somebody ripped off my Catalytic converter on my truck and I replaced it with one of those cheap Chinese universal ceramic converters.
I'm not sure if it will pass. The engine is a 4.0L I-6.
Should I bother putting in some premium gas?
What about adding some Seafoam to the gas tank? Or would that make it worse by breaking up carbon?
Old 09-20-2010, 07:01 PM
maxwedge maxwedge is offline
A990 racer
Re: Need to pass emissions test
None of that will do anyhing see if it passes, what else would you do? Was the cat epa certified?
Old 09-20-2010, 09:44 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
If the check engine light is not on, run it thru the test and see what happens...
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 09-20-2010, 09:58 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
This sounds like an older Jeep. It sure helps us if you state the make, model and year.
For example:
As Blt says, if your car is 1995 or newer, it has OBDII, so the functioning of the cat is, in part, monitired by the ECM, so a malfunctioning cat may likely result in a check engine light. Pre-'95 vehicles often do not produce a check engine light when the cat is bad.
IMO change the engine oil and filter, make sure the air filter is clean, make sure the engine and cat are fully warmed-up when you do the test, and go for it.
Old 09-21-2010, 11:59 AM
It's a 92 Jeep Cherokee, and I got one of these cheap Marmont cats from Autozone.
Old 09-21-2010, 02:08 PM
Blt2Lst's Avatar
Your lucky your not in California (or maybe not so lucky ), those would not pass smog here with the new smog laws.
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 09-21-2010, 06:49 PM
A990 racer
In Ny Pre 95 cars do not get tailpipe tested, only the NYC area.
Old 09-22-2010, 05:00 PM
534BC 534BC is offline
In Cuyahoga county they should check the light on 1996 , and for 1995-1986 should run it on the rollers. You can also tell them it is full time 4wd and they will not roller it. It is free anyways, try it and see if it passes.
Old 09-23-2010, 01:03 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Replacement cats should be warranted against defects and have to be certified for sale, so you should be fine getting tested. At worst, you pay your money, it fails, you get it replaced with a good one, and the re-test is usually free within a certain time.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-23-2010, 01:38 PM
How would I be able to get away with that? All they have to do is look in the truck and see its not full time 4wd.
Old 09-23-2010, 01:39 PM
I'm wondering If the auto parts store would accept the return of a Catalytic converter.
Old 09-24-2010, 08:58 AM
jdmccright's Avatar
The RustBuster
Sounds like you're getting ahead of yourself...or as some people call it "advance planning". Have the test done first, then worry about any problems if they arise. Besides, if you do happen to fail, you can show that the OBD is working and the proof of the recently installed cat...they may grant a waiver or allow a retest.
If you are pre-1996, then the only way the "check engine" light will come on for an exhaust issue will be for a faulty or abnormal reading (i.e. too rich or too lean) from the upstream O2 sensor, there are no O2 sensors after the cat.
As far as returning the cat if need be, check your receipt. The terms are usually printed right there for warranted items.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-26-2010, 09:23 PM
Should I drive around a while with the new cat on before I get the emissions test? Would there be any problems if I put it on right before the test?
Old 09-27-2010, 12:49 AM
danielsatur danielsatur is offline
OBD I system is usually a visual inspection for a catalytic converter.
Take your car in for the inspection, after reaching normal operating temp.
Old 09-27-2010, 08:25 AM
jdmccright's Avatar
The RustBuster
I see no reason to wait for the cat to "break in". If you are coming due for testing soon, then just go and do it. Again, if something does fail, you have the proof of purhcase and qualified install. But it won't hurt if you let it go through a few heat cycles to allow any volatiles left over from the manufacturing process to be burned off. A week's worth of driving should be plenty of time for that.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
