Old 09-20-2010, 04:54 AM
Chieflongshin Chieflongshin is offline
Eliminating brush strokes
Another quick one from me please
With the exception of not using a brush is there a good way to reduce brush strokes when painting with tamiya acrylics.
i've primed all the interior of vehicle however paint is going on streaky. I've used no thinner as it appears that way at present. Can someone help with how to do this or is it just a case of bulding the paint up layer by layer
Cheers
Old 09-20-2010, 08:18 AM
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
Re: Eliminating brush strokes
It's been my experience that Tamiya acrylics don't brush worth a darn unless the coverage area is very small. I've tried thinning etc but no luck. My solution was to only use them through an airbrush. I think they are quite nice applied in that way. Perhaps someone else has a brush technique we might all benefit from. Retarders?
For small details I brush paint using Model Master Enamels from Testors thinned down to help them flow and level better. Even they give me trouble with semigloss. Flats and gloss finishes flow well as long as the area is limited. I almost always spray wide open flat areas from a can or airbrush however.
Old 09-20-2010, 09:47 AM
ariel's Avatar
ariel ariel is offline
I've used this with some sort of success
http://www.liquitex.com/Products/addslowdrifluid.cfm
HUMAN IS TO ER
www.pacms.org
http://www.mamasboyz.org/
Old 09-20-2010, 07:05 PM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
I use a thinned down version so you have to put a few coats on
The whole body on this was brush painted:-
http://www.escalemodels.com/forums/i...showtopic=7823
or
Old 09-20-2010, 10:39 PM
Tamiya makes an acrylic paint retarder but I've never tried it so can't say anything about it. Has anyone tried it? Or know how to get it in the US?
http://www.tamiya.com/english/produc...rder/index.htm
Old 09-21-2010, 01:07 PM
Didymus Didymus is offline
Genuine Tamiya thinner for acrylics (X-20A) will help eliminate brush marks. It also helps to use an artists brush with soft bristles.
But the best way to get a smoothly finished interior is by spraying. I really like Floquil or Testors flat enamel thinned with lacquer thinner.
If you can't manage an airbrush right now, try spraying with a flat-finish Rustoleum or Krylon. By the way, the flattest and blackest flat black I've found is Rustoleum flat black "Protective Enamel."
D D M S
Old 09-21-2010, 01:09 PM
Nice work! What kind of thinner did you use?
D D M S
Old 09-21-2010, 07:36 PM
Drift F.C's Avatar
It's a thing called water
or
Old 09-21-2010, 09:45 PM
Huh. I've heard of that stuff. Never use it, though.
D D M S
